Latest post Sat, Nov 17 2018 3:46 PM by DStone. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Nov 16 2018 10:46 PM
    • grizzli
    • Joined on Fri, Nov 16 2018
    • Posts 1
    • Points 15
    MC-First App Manager on Win-10 does not launch
    I am currently running Adobe Premiere on a hi-end Dell 5810 Win-10 64-bit workstation with 32GB Ram, SSD boot, Xeon 3.7Ghz processor with with 4.0Ghz Intel Turbo Boost Max, NVIDIA Quadro M2000 4GB and tons of high-speed drives. Premiere runs without a hitch.
    At recommendation of colleagues I am attempting to install Avid MC - First for evaluation. The first time I installed it  (took nearly an hour) I managed to get it running for a brief period. Since then it cannot be launched as it seems to require OK from 'Application Manager'. This ill-behaved and opaque piece of software refuses to launch. After apparently following the path of numerous others, i.e. clean installs, reboots, tinkering with firewall settings, turning off anit-virus and malware I get nada! The progress wheel spins for about 2 nano seconds then nothing.
    Given the depth and sophistication of Avid's product offerings I find it bizarre and puzzling that this seemingly simple piece of software is so poorly implemented. In failure it provides no diagnostic or feedback. If MC-First is intended to be a gateway for new customers one would think that it would be made to work flawlessly or at least fail elegantly. It makes no sense that it would run once and then become dead disk space. Not an encouraging prospect for becoming an Avid user.
    How in the hell do you get this thing to work???
  • Sat, Nov 17 2018 3:46 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: MC-First App Manager on Win-10 does not launch
    First, make sure that you're logged into the Avid Application Manager. If you're not, MCF won't launch (but you should also get a login error message).
    Dave S.
