Hi. Firstly this worked on Monday and I have not knowingly made any changes to my system since then, but yesterday and today I am unable to log in to application manager with it getting stuck at the "Getting subscription data" message.
I am using Windows 10 64-bit.
Things I have already tried:
1) Turned off my system firewall completely
2) uninstalled and reinstalled both media composer and application manager
3) Gone to preferences and clicked 'Clear Cache files' & 'Restart App Man Helper' and restarted the application manager
4) Physically deleted the AppManager folder in c:\programdata\Avid (app manager has subsequently recreated this folder
5) pinged the avid servers at:
https://license.avid.com:3443/ping.aspx
https://license.avid.com:443/ping.aspx
http://update.avid.com:96/ping.asp
6) restarted my pc (several times)
7) Updating application manager to the latest version.
So far nothing has had an impact. So from a system that was working perfectly two days ago i cannot access Media Composer. I'm due to present a video on Friday so any help for me to regain access to my project would be really really appreciated! Up to now I've been a happy user of Media composer First and have been considering upgrading to make this my primary tool, but I need to know that the licensing is robust.
I have the sampe problem here. I use also windows 10.
Raff is going to work with you on this....
Stand by
Thanks, MM, the issue is now resolved, please pm MM or me if you're still getting the same issue.
RalphC
Hello,
I have the same problem also, all was working well last week but today the app manager is stuck on initializing.
I do all the same than the first personn to post (restarting, reinstalling, deleting cache, try to log without firewall...)
If you have a solution.
Marcel
email me your system ID and My Avid email and the error
I think it was solve but its happens again.
Sometimes if I wait long long time (almost 1 hour this morning) it go to that:
The connect line is grey I can only quit and sometimes, if I'm lucky enough, when I restart I have the login.
But not this morning. :(
I'm having the same issue on macOS Sierra. What, pray tell, is a "system ID"?
must be your system specs.
I don't get a solution for that, seems it don't exist.
The best thing to do is certainly to say goodbye to Avid and install another software.
Good day
Walter Ian Kaye: I'm having the same issue on macOS Sierra. What, pray tell, is a "system ID"?
Walter - MC First products dont require a System ID. Can you please email me your MY Avid email address and I can help you.
Marcel Clinquant: Hello, I think it was solve but its happens again. Sometimes if I wait long long time (almost 1 hour this morning) it go to that: The connect line is grey I can only quit and sometimes, if I'm lucky enough, when I restart I have the login. But not this morning. :( Marcel
Marcel - can you email me your MyAvid email address please?
OK, email sent!
Hi Walter,
I sent you an email. Thanks!
