Hi
Im trying to export a Boris FX Tilte on a seperate tack as a quicktime. Track 3 is only slected . I check 'use selected tracks' in the quicktime settings but it does a mix down of all video traks
Am I missing something
best Ulrich
That is normal behaviour, if you want to only see the title you could mute the clips underneath or subclip it out and export the subclip.
If you command click on the track view icon you “solo” the track (the track view icon goes green) ,that may work too?
Ulrich Thomsen: Im trying to export a Boris FX Tilte on a seperate tack as a quicktime. Track 3 is only slected . I check 'use selected tracks' in the quicktime settings but it does a mix down of all video traks
As the other response gave some ways to address what you are "seeing", please know that any export from Media Composer will NOT have an alpha channel. That is not supported. You will only get the fill as a full screen image.
Jef
Jef Huey
soloed works. thanks... subclip sure. Just dont understand that quiktime setting then ... selected tracks
yes I know that... sucks though. Talking to Boris FX too. currently there's no way to fix that. Also Boris FX Title Studio doesnt export. The suggest that the posthouse get a copy of Boris FX themselves :-) before you make final mixdown
