I am trying to open a sequence I created a few years ago and keep getting this error whenever I try to play it:
"Exception: Failed to get sample position from the AMA plug-in"
When I originally created the sequence, I consolidated the shots to DNxHD and deleted the AMA version of the clips. I can Match Frame to the shots and they are there--I can play them and cut them in to a new sequence. I have checked every bin in the project and there no AMA linked clips.
I have a fantastic editing assistant. He stays by my side when I edit...doesn't talk too much...and thinks I'm a genius! Check him out here: www.youtube.com/watch?v=ZQVkYaaPO6g
Hi Terry
I 'd check that the original files on the disk are Ok and NOT corrupt.
Play using a third party player such as VLC.
If the media file itself is corrupt you'll need to restore it from a backup. If it checks out, try copying the file to a new drive, hiding the original from Avid and re-linking it. Note that sometimes links separate media files in to a single file (XDCAM for example will string multiple 2G files together) that can also cause this.
If that isnt it then I suggest you contact support and have a tech check your computer and MC out.
Hi Marianna,
The weird thing is the clips play fine in the bin and I can cut them into a new sequence. When I click the monitor on the top track (a video mixdown) I can play the sequence, but selecting the monitor for any other video tracks (even tracks not containing clips such as titles, etc.) gives the error and the sequence won't play.
I checked all the bins in this project and don't have any AMA linked clips. Is there a way to force a "break" to any AMA link that is hiding somewhere and interfering with the playback?
Hello,I would try to view the colors of the clip in the timeline and tick the AMA.Next, I would try to cut the sequence into a new sequence (not duplication, create a new sequence and then cut off the original sequence).
V.
Vilem:I would try to view the colors of the clip in the timeline and tick the AMA.
Not sure what you mean? Open up color correction?
Vilem:Next, I would try to cut the sequence into a new sequence (not duplication, create a new sequence and then cut off the original sequence).
I did that and I still get the error.
Terry Snyder: Vilem:I would try to view the colors of the clip in the timeline and tick the AMA. Not sure what you mean? Open up color correction?
Quick menu at the bottom left of the timeline, "Clip color", see the attached picture.I would also try to consolidate the sequence with the "Consolidate only linked media"
Thanks. I was able to find the clips that were AMA linked to footage no longer available. After deleting these from the timeline, I was able to play the sequence.
On future versions of MC, it would be great if MC would still play the sequence but simply display a black screen with the words "AMA clip off line" (or something to that effect) the same way it gives a "Media Offline" message but still keeps playing. As it stands now, if there is a single broken AMA link in a sequence, MC won't play the sequence at all and displays the "Failed to get sample position from the AMA plugin" error.
Hi there,
I also thave this problem now. A whole sequence, ll the sequences in this project, EVERYTHING, I cannot play it back. all has gone offline too, cannotr be linked or touched anyway. I still have been workling on it today, now the whole project ist unusable. I evene deleted the AMA management folder, as it has been sugested on a different forum, but no success. another project, htat used to work too, I cannot even export it. Everything I hve been working until now, is inaccessible. Also MC has started to crash with every move I do. Many days of work is destroyed and as I am in a hurry, i need to thing about going over to a different softwar, maybe having to purchase Adobe Cloud. and redo the whol lot again. Can't even imagine, what a mess this is.
PLEASE HELP!!!!
I worl on a Mac Min 16GB Memory, used to work allright, everything till now. And that happened on a other proeject in a earlier version before, but not for whiole, unti lnow. And why cannot i not export same a source? What is Long GOP? thannks, Anita
Thanks you, Anita
