Latest post Mon, Sep 24 2018 9:39 PM by Kevin Klimek. 4 replies.
  • Fri, Sep 21 2018 8:27 PM
    • pierreh
    • Paris, London
    • Posts 1,214
    • Points 14,695
    Shared Nexis questions
    I'm working on a project with a shared Avid storage system. I'm used to "DIY Sharing" with mirror copies of the mediafiles on external drives, but that's different. So I have a couple of questions.
    The project was setup on one of the shared drive which are mounting automatically when Nexis starts. It's the right way to do it? Shouldn't the project be on the internal HD of each Mac in the Shared Avid Projects?
    Also, the post-house is running all Macs, with OS 10.2.6 and Media Composer 8.6. The Nexis Client app is 18.5. We'd like to run a more current version of MC so we can have ScriptSync II (at least MC8.8 then) or why not 2018.9 since the iMacs are qualified. Would it work in this environment or is there some kind of version matrix to follow to line up the MC version with the Nexis and so on? The techs here claim it'll never work and it's not possible and MC2018.x is rubbish. I suspect them to not want to pay to update their dongles which are out of contract...
  • Fri, Sep 21 2018 8:41 PM In reply to
    • Posts 10,149
    • Points 217,245
    Re: Shared Nexis questions
    Ha pierreh my friend....
    Just working on this very thing.
    http://resources.avid.com/SupportFiles/attach/AvidNEXIS/AvidNEXIS_ReadMe_v2018.6.pdf
    http://resources.avid.com/supportfiles/attach/Mac_Current_CPU_Specifications.pdf
    Make sure you are on NEXIS 2018.4 of higher and the corresponding MC.
  • Sat, Sep 22 2018 5:12 AM In reply to
    pierreh:
    No, not if you want to use true Avid-style project sharing. In the case of true Avid project sharing, the project lives on a NEXIS volume, and multiple clients can work in the same project simultaneously. Whoever opens a bin first will automatically get read/write permission, and everyone who opens a bin second, will automatically get read-only rights to that bin. This way, MC ensures no conflicts happen.
    I don't think version compatibility between MC and NEXIS clients tend to matter. NEXIS client versions and NEXIS sytem versions do. And then OS version may come into play at some point.
  • Sat, Sep 22 2018 9:27 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,214
    • Points 14,695
    I knew I could rely on you two for help! Thanks!
    Is there a way to know the version Nexis is running from the "client" side? Or do I have to ask the techies at the post-house?
    I always used the "Shared Avid Projects" on my Macs as the private one used to be the best source of permissions/access problems back in the early days of OSX. But for some reason I thought it had to do with shared storage too!
  • Mon, Sep 24 2018 9:39 PM In reply to
    "Shared Avid Projects" are just shared within multiple users of that CPU. You actually want "External" for shared storage.
