Latest post Thu, Sep 20 2018 10:43 PM by MikaS. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Sep 19 2018 8:40 AM
    • MikaS
    • Munich, Germany
    • Posts 34
    • Points 370
    Waveform Jittering
    Supposedly not an Avid issue but I searched other forums with no luck: with MC, formerly I used Matrox MXO2 mini and the component output into Tektronix WMF-300 waveform monitor very happily. Since I changed to Blackmagic Intensity Pro and the same buildup, the video signal (both parade and vector) is vertically heavily jittering.
    Any clues?
    MC 2018.9 w/ Intensity Pro, MSI X99A SLI, Win 10 Prof., Intel i7-6800K 3.4GHz, 32GB Ram, GeForce GTX 1070, 15TB Raid, 500GB SSD System. 2nd: MC 7.0.6.02... [view my complete system specs]
  • Wed, Sep 19 2018 3:19 PM In reply to
    • Posts 10,227
    • Points 218,320
    Re: Waveform Jittering
    Mikas...
    the only issues wee have seen with jitter is Bug Number: MCCET-2248. Occasionally, you might have seen playback jitter when creating XDCAM HD 50 media.
    This was fixed in 2018.6
  • Wed, Sep 19 2018 7:55 PM In reply to
    • MikaS
    • Munich, Germany
    • Posts 34
    • Points 370
    Thanks. I use video formats of all kind, transcoded or not, there is no difference.
    I upgraded to 2018.9 and the latest Intensity driver with no change.
    But I found that there is jitter only with progressive framerates, not with interlaced, chosen in the Format Preset menu.
    This is independent of the original framerate of the video and independent of the framerate when the project was created.
    I would prefer no jitter in progressive projects but I suspect it's the waveform monitors fault, it might not manage progressive video.
  • Wed, Sep 19 2018 8:31 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Correct me if I'm wrong, but isn't that monitor circa 1960? It's certainly NTSC only.
    Dave S.
  • Wed, Sep 19 2018 9:38 PM In reply to
    • MikaS
    • Munich, Germany
    • Posts 34
    • Points 370
    It't from the 80s and component analog, yes, but I feed it with that kind of signal. The point seems to be "progressive".
  • Thu, Sep 20 2018 2:27 AM In reply to
    If you can get a composite output from the Intensity Pro at the same time as your component output you could try connecting the composite out to the waveform monitors reference in and then 75 ohm terminate the reference in (if it is loop through).
  • Thu, Sep 20 2018 8:24 PM In reply to
    MikaS:
    P or PsF?
  • Thu, Sep 20 2018 9:24 PM In reply to
    • MikaS
    • Munich, Germany
    • Posts 34
    • Points 370
    Alayne, there is no separate video out, the waveform picks the sync from the Y channel of the component signal.
  • Thu, Sep 20 2018 10:43 PM In reply to
    • MikaS
    • Munich, Germany
    • Posts 34
    • Points 370
    Should be P according to the specs of the cameras.
