Latest post Fri, Sep 14 2018 4:13 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Sep 11 2018 1:05 PM
    Stills on the timeline?
    Normal 0 false false false EN-GB X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
    Hi, quickie question:
    Having converted a JPEG to MXF, when placing a still onto the timeline the default setting is for 30 seconds’ worth.  Can I change this to anything, even 1 or 2 frames only.  This would save a lot of adjustment time.
    Thank you,
    DC
    Asus N55SF Notebook running Windows 10 Home Processor: Intel(R) Core (TM) i7-2670QM CPU @ 2.20GHz 2.20GHz Installed memory (RAM): 8.00 GB System type... [view my complete system specs]
  • Tue, Sep 11 2018 1:09 PM In reply to
    Re: Stills on the timeline?
    (erm, I don't understand how that font info, etc., above was reproduced. I can't edit it out. Odd.)
  • Tue, Sep 11 2018 2:31 PM In reply to
    • Posts 10,156
    • Points 217,355
    did you write the note somewhere else and cut and paste it in?
  • Tue, Sep 11 2018 3:55 PM In reply to
    Hi Marianna,
    Yes, I did.  That explains it.
    Also, do you have an answer for the main question?
    DC
  • Fri, Sep 14 2018 3:02 PM In reply to
    Can anyone please answer the initial question?
    Thank you,
    DC
  • Fri, Sep 14 2018 4:00 PM In reply to
  • Fri, Sep 14 2018 4:13 PM In reply to
    • Posts 10,156
    • Points 217,355
    Superman....
    Sorry dan but I was off the internet yetserday thanks to Frontier :( but Im back online and then had to launch 2019.9 this am at 4:00 in conjuction with IBC.
    Here is the scoop....    We have longer term plans to make this more flexible, but today it's 30 seconds.  You can always put a "both fields" timewarp on the jpg image and trim as far as needed.
