Latest post Mon, Aug 27 2018 4:34 PM by Marianna. 1 replies.
Page 1 of 1 (2 items)
  • Sun, Aug 26 2018 3:30 PM
    • Flavio Nunes
    • Rio de Janeiro
    • Posts 2
    • Points 30
    Fps column empty !
    I edit a novel where they use Sony f55 cameras and managed through silverstack. We use Glookast to import and Interplay to make master-clips available to publishers. The Bin FPS column is empty, however in the SIlverstack .pdf report, the value is there, 24fps, 60fps etc.
    How do I get the fps information to appear in the fps column of the bin?
    Thank you.
  • Mon, Aug 27 2018 4:34 PM In reply to
    • Posts 10,204
    • Points 218,090
    Re: Fps column empty !
    YUMES...
    Can you edit yuor profile ( click on your name in the upper right corner )?  Select edit profile on the left and add all your system spec's.  OS and MC version important as is interplay etc.....
    help us help you
