Latest post Fri, Aug 31 2018 3:51 PM by Marianna. 17 replies.
  • Fri, Aug 24 2018 9:32 PM
    • zebramedia
    • Joined on Fri, Oct 28 2011
    • Posts 4
    • Points 60
    XDCAM MXF OP1A NOT AVAILABLE IN RELEASE 2018.8
    Operating system: Mac OS Hight Sierra / 10.13.5
    I just installed the latest version of Avid Media Composer and XDCAM MXF OP1A exporting is not available. Without this option we can't delivery our tv commercial becaus is the only way the broadcasters accept the closed caption files.
    Other users have the same probleme?
  • Sun, Aug 26 2018 3:38 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,526
    • Points 45,360
    Re: XDCAM MXF OP1A NOT AVAILABLE IN RELEASE 2018.8
    To export XDCAM OP1A, select Avid Media Processor From the Export As selection box. You'll find the XDCAM options in the Video Compression dropdown.
    Dave S.
  • Mon, Aug 27 2018 5:54 PM In reply to
    • zebramedia
    • Posts 4
    • Points 60
    not xdcam only but xdcam mxf op1a, is the only way to export data track with closed caption
  • Mon, Aug 27 2018 7:48 PM In reply to
    • Posts 10,079
    • Points 216,475
    With 2018.8, when exporting XDCAM OP1a, you select XDCAM through the Avid Media Processor.
    When exporting using the Avid Media Processor, XDCAM OP1a is not limited to the same export formats as XDCAM optical devices as it was in previous releases of the editing application.
    To export to XDCAM:
    1. Choose the file you want to export to XDCAM.
    2. Select File > Output > Export to File.
    3. Click Options.
    4. In the Export As pulldown, select Avid Media Processor.
    HTH
    marianna
  • Tue, Aug 28 2018 6:15 PM In reply to
    • AyQueSi
    • Joined on Tue, Aug 28 2018
    • Posts 5
    • Points 75
    Hi, I just installed Avid Media Composer 2018.8 and I cannot export XDCAM files like I did before. I red the manual and it says the option to do so is now under "Avid Media Processor" in the export options, but it does not show for me. A  client is expecting a XDCAM MXF file from me and I cannot do it. Tried reinstalling and no luck. Does someone has some advise on this, please?
    Thanks!
  • Wed, Aug 29 2018 3:03 PM In reply to
    • Posts 10,079
    • Points 216,475
    Hey there....
    If you followed my instructions above then it should be there....  I created a case for you with support 03539785 and they will reach out to check your system.
    Can you please add your system specifications to your profile.  Click on your name in the right corner then select edit proile and add yout OS, Computer, graphics etc....
  • Wed, Aug 29 2018 4:35 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,526
    • Points 45,360
    The XDCAM export options do not appear if your media doesn't conform to XDCAM specifications (so something like a 4k DCI 2 48P is right out). Exactly what are the video and audio spec's?
    Dave S.
  • Wed, Aug 29 2018 5:03 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,526
    • Points 45,360
    Also an easy test: Create a new project (1080i/59.94) and use just the defaults. Add an empty sequence, and then output the sequence using  Avid Media Processor. See if the XDCAM options are available.
    Dave S.
  • Wed, Aug 29 2018 5:33 PM In reply to
    • AyQueSi
    • Posts 5
    • Points 75
    No luck, Avid Media Processor does not show nor in the Export... option or the AMA File Export option. I tried every drop down menu and it is not there for me.
  • Wed, Aug 29 2018 6:16 PM In reply to
    • zebramedia
    • Posts 4
    • Points 60
    Ok i have the answer of Avid...
    The export dialogue for the XDCAM MXF was moved in the 2018.8 release of Media Composer. Please check this document for confirmation:
    http://resources.avid.com/SupportFiles/attach/WhatsNew_MediaComposer_v18.8.pdf (page 3 - Exporting to XDCAM Change)
  • Wed, Aug 29 2018 6:36 PM In reply to
    • AyQueSi
    • Posts 5
    • Points 75
    Hi, does the Avid Media Processor show for you there? It does not for me. I don't know if it is a config problem or a bug, but I can't find it anywhere.
  • Thu, Aug 30 2018 1:50 PM In reply to
    • Posts 10,079
    • Points 216,475
    Now it sounds like a plug-in conflict ....  are there any plug in's that you have on the PC before you upgraded to 2018.8 that might be causing this?
  • Thu, Aug 30 2018 3:28 PM In reply to
    • zebramedia
    • Posts 4
    • Points 60
    No, it's work fine now with the instruction from Avid tanks for all!
  • Thu, Aug 30 2018 3:49 PM In reply to
    • Posts 10,079
    • Points 216,475
    zebramedia:
    Great news!
    Happy editing.
  • Thu, Aug 30 2018 5:57 PM In reply to
    • AyQueSi
    • Posts 5
    • Points 75
    Hi Marianna, just tried uninstalling the plugins and reinstalling MC and Avid Media Processor still does not show in the drop down menu.
