Latest post Fri, Jul 13 2018 5:30 PM by greggogo. 4 replies.
  • Fri, Jul 13 2018 10:06 AM
    • greggogo
    • Joined on Tue, Jan 20 2009
    • Posts 7
    • Points 75
    4 camera clips synchronized on a realtime timeline
    Hello,
    I had a 4 synchronised cameras realisation in reporter style. Each camera man was stopping his camera, so I've got a lot of clips from ich camera. I'd like to create a timeline with a real TC, showing when the camera operator was recording and when was a break. So the timeline would be an time axis and on V1, V2, V3, V4 I would have each camera or a milticamera. It would show me synchronised clips to a timeline. Is it possible to create such timeline witch sync clips automaticly?
    Regards
    Greg
    AVID MC 8.4.1 / iMac Retina 5K 27" 2017 / Intel Core i7 4,2 Ghz, 40GB RAM, Radeon Pro 580 8192 MB / macOS High Sierra 10.13.6 [view my complete system specs]
  • Fri, Jul 13 2018 12:55 PM In reply to
    Re: 4 camera clips synchronized on a realtime timeline
    Hi Greg,
    This might work:
    1. Select all the clips from camera 1
    2. From the Clip menu, select Autosequence
    This will make a sequence from all the Camera 1 clips, spacing them out by timecode and leaving gaps when the camera wasn't rolling.
    3. Repeat 1 & 2 for cameras 2-4
    Now you should have 1 sequence for each camera. You can then use each sequence as a source to make the timeline you want. You'll have to sync the start of each sequence yourself.
    I hope that helps.
  • Fri, Jul 13 2018 4:53 PM In reply to
    • greggogo
    • Posts 7
    • Points 75
    I forgot to write that I've got a dongle 8.4.1 MC version.... I don't see Autosequence command in Clip menu... Is there another solution?
    Thank you
    Greg
  • Fri, Jul 13 2018 5:20 PM In reply to
    Hi Greg,
    In older versions it might be under the Bin menu rather than the clip menu.
    Carl
  • Fri, Jul 13 2018 5:30 PM In reply to
    • greggogo
    • Posts 7
    • Points 75
    Thanks a lot there is autosequence in bin :)  It works :)
    Greg
