Latest post Thu, Jul 5 2018 7:20 PM by mark.burton. 3 replies.
  • Thu, Jul 5 2018 6:46 PM
    • mark.burton
    • London, UK
    • Posts 908
    • Points 11,050
    Output 5.1 via 3 x AES pairs?
    I have a 1080p 24fps, 5.1 sequence with 5.1 DME's. I'm going to play this back in a theatre that can only accept the audio on 3 AES pairs:
    L / R
    C / Lfe
    Ls / Rs
    I have either an Avid DNxIO or an AJA IO 4K.
    Can anyone explain which hardware is suitable (not sure DNxIO can do this?) and how I should have the audio ouput settings.
    Many thanks
    Mark
  • Thu, Jul 5 2018 6:52 PM In reply to
    • mark.burton
    • London, UK
    • Posts 908
    • Points 11,050
    Re: Output 5.1 via 3 x AES pairs?
    I'm thinking this is not possible with this hardware. No AES on the IO 4K and only 2 Channels of AES on the DNxIO.
    So I guess I would need an audio AES de-embedder and send the audio over SDI?
  • Thu, Jul 5 2018 7:08 PM In reply to
    If the DNxIO is like the Nitris DX (not sure as we have the Nitris) you may only be able to surround out the HDMI port.
  • Thu, Jul 5 2018 7:20 PM In reply to
    • mark.burton
    • London, UK
    • Posts 908
    • Points 11,050
    Yeah, I think you're right.
    How about an AES audio de-embedder like this one:
    Mini Converter SDI to Audio
    https://www.blackmagicdesign.com/uk/products/miniconverters/techspecs/W-CONM-22
    Even though all my 5.1 DME's are in ProTools 5.1 order (L C R Ls Rs Lfe), in order for them to de-embed in the right pairs on the AES outputs, I think I would need to set the Media Composer output to SMPTE 5.1 order (L R C Lfe Ls Rs).
    Does that sound even remotely plausible? Output in SMPTE order, de-embed from the Blackmagic box, which would take the 6 channels as follows:
    AES Pair 1 - Ch1 + Ch2 (L / R)
    AES Pair 2 - Ch3 + Ch4 (C / Lfe)
    AES Pair 3 - Ch5 + Ch6 (Ls / Rs)
