Latest post Fri, Jul 6 2018 9:03 AM by Hannes Schuler. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jun 25 2018 11:44 AM
    Avid MC 2018.5 crashes on launch
    Hi, I just downloaded and installed MC 2018.5 and it wont open. It crashes on launch each time when it gets to 'ACFString.avx' plugin.
    I'm running OS High Sierra 10.13.5
    Is there a known issue with this?
    Many thanks for any suggestions.
  • Wed, Jun 27 2018 1:43 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,731
    • Points 19,055
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Avid MC 2018.5 crashes on launch
    Hi Hugh,
      MC 2018.5 is not yet qualified with Mac OS X 10.13.5.
    RalphC
  • Thu, Jul 5 2018 2:58 PM In reply to
    Hello,
    I have the same problem after upgrading to 2018.5 while the launch process with the same message BUT on Mac OSX Sierra 10.12.6.
    But this ONLY happens, when the external HD-Video Monitor is connected.
    I did not realize it in the beginning, because I installed and tried 2018.5 on my Macbook Pro first, without any external monitors etc. Everything was fine. When I connected my Macbook Pro to it's editing ‚ecosystem‘ with external monitor, external keyboard, Artist Color Control, Raid etc. Avid crashed when I tried to start it. It was a long process to single out the reason for the crash: the external HD Monitor, connected via Blackmagic Ultra Studio MiniMonitor WITH external HD monitor connected: Avid crashes on launch each time it reaches ‚ACFString.avx‘ plugin WITHOUT external HD Monitor: No problems… I already uninstalled and installed MC 2018.5 but unfortunately the problem (=crash) stays… Any suggestions? Thank you and kind regards, Hannes
    MacOSX High Sierra 13.10.6 MacBook Pro 2018 Modell-Identifizierung: MacBookPro15,1 Intel Core i9, 2,9 GHz kernels: 6 L2-Cache (pro Kern): 256 KB... [view my complete system specs]
  • Thu, Jul 5 2018 3:30 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 315
    • Points 3,615
    what version of blcakmagic software?
    Dave
    "A very big network"
  • Thu, Jul 5 2018 4:06 PM In reply to
    I tried to check the version of the ‘Blackmagic desktop video’ in the system configurations but it didn’t open. Instead an error occured ‚Blackmagic desktop video couldn’t load’ (original the message is in German...).
    So that might be the problem?
    And I haven’t touched the Blackmagic software for probably years... Should I try to find an update?
    Tnank you!
  • Thu, Jul 5 2018 5:03 PM In reply to
    • NYnutz
    • New York City
    • Posts 315
    • Points 3,615
    Yes, definitely! Blackmagic software versions are just as sensitive to the OS version and client/host software versions as media composer! You should download the version that is qualified for your OS and media composer versions, then use the installer utility to UNINSTALL the existing version FIRST. Once the existing version is uninstalled, you should install the new version.
    Here is a link to the blackmagic support and downloads page for capture and playback hardware.
    Dave
  • Fri, Jul 6 2018 9:03 AM In reply to
    Thank you!
    That solved the problem (and looking back it it's very obvious thagt this was the problem but I didn't see it...).
    First I tried the newest BM desktop video software which should work according to the specs, but it didn't.
    But version Blackmagic_Desktop_Video_10.9.12 worked in connection with Mac OSX 10.12.6 and Avid MC 2018.5
    Thanks again,
    Hannes
