Latest post Thu, Feb 14 2019 11:31 AM by Hansa. 15 replies.
  • Fri, Jun 22 2018 10:24 AM
    • AlexisK
    • Joined on Thu, Jun 21 2018
    • Posts 4
    • Points 70
    Composer v2018 : flickering SubCaps !
    p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
    Hi !
    I’m currently working on a documentary feature film in which we needed to subtitle in progress. This is on Composer 2018.4.0.
    We used a track with a 3D LUT, and above, a track with SubCaps.
    Unfortunately, some of the subcaps are kind of flickering / shaking (and even jumping) for about 1 frame time, suddenly set in the middle of screen before coming back at the right place.
    This flickering happens randomly, and from one cut to another, you don’t see the same jumping subcaps…
    -I checked that there’s no keyframes in Position of the Subcap FX
    -I tried to invert LUT-track and Sub-track
    -I tried to render the whole video.
    Day by day, some of them stop flickering - some others start to…
    Do you know something about this issue ?
    Thanks a lot !
    Alexis
  • Thu, Jul 26 2018 6:37 AM In reply to
    • RobertBe
    • Joined on Fri, Dec 18 2015
    • Posts 6
    • Points 80
    Re: Composer v2018 : flickering SubCaps !
    Hi Alexis, i have the same issue here. Have you you a found a solution meanwhile?
    Robert
  • Thu, Jul 26 2018 2:32 PM In reply to
    • Posts 10,079
    • Points 216,475
    A bug has been logged on this and is in progress..... which means engineering is looking at it.
    MCCET-2467
  • Tue, Aug 28 2018 8:43 AM In reply to
    • Hansa
    • Joined on Tue, Sep 5 2006
    • Edinburgh, Scotland
    • Posts 415
    • Points 5,190
    Is there any update on this bug? Is it fixed in 2018.8?
    I have a student one day away from his hand-in with this issue in MC 2018.4 and we need a solution.
    Thanks.
    Avid DNxIO, 3.5 GHz late 2013 Mac Pro, 64 GB Ram, MC 2018.10 with Symphony option, OS 10.12.6, LaCie 24 TB RAID. 3.5 GHz 6 core Mac Pros x 5, MC 2018.4... [view my complete system specs]
  • Tue, Aug 28 2018 1:57 PM In reply to
    • Posts 10,079
    • Points 216,475
    Hansa
    Still in progress and not fixed yet.
  • Tue, Aug 28 2018 3:29 PM In reply to
    • Hansa
    • Posts 415
    • Points 5,190
    Thanks for the update.
    Did this bug first appear in 2018.4 is there any point going back before 2018.4 when working with subcap generator?
  • Tue, Aug 28 2018 3:55 PM In reply to
    • Posts 10,079
    • Points 216,475
    Hansa
    The bug bwas in 2018.5 so 2018.4 is safe for now.
  • Tue, Sep 4 2018 6:47 AM In reply to
    Media Composer 2018.7.1 here.
    Same problem having with the flickering in SubCap. I have a H264 AMA Linked clip in my timeline.
    After transcoding it to MXF flickes less, but still I have to run through each subtitle to check, so i have to run through the entire film to re-edit the text or the position, and after few tries it works, but i lose lot of time.
    Hope one day this bug will be fixed, and it would work directly with AMA Linked files.
  • Wed, Sep 12 2018 8:33 PM In reply to
    • AlexisK
    • Posts 4
    • Points 70
    For now the only solution I found is to go back on an older version of Avid (6 or 8) to make subtitles there...
    Eager for an update !
  • Tue, Nov 13 2018 1:29 PM In reply to
    • stefan kamp
    • Joined on Tue, Aug 21 2012
    • amsterdam
    • Posts 12
    • Points 140
    solution urgently needed...since I am working on several projects, I can't go back to an older version few times a week.
  • Tue, Nov 13 2018 1:35 PM In reply to
    I found the solution for this bug. I observed that it didn't flicker when I have 2 raws in subcap, it is flickering only when I have only one, so on the empty row if you press space ( like an ascii invisible character) it solves the problem.
  • Tue, Nov 13 2018 2:37 PM In reply to
    • stefan kamp
    • amsterdam
    • Posts 12
    • Points 140
    mmm..thanks, but it didn't work on my side though...
  • Tue, Nov 13 2018 2:40 PM In reply to
    If you render it it will work.
  • Thu, Feb 7 2019 5:23 PM In reply to
    • Posts 10,079
    • Points 216,475
    Hey all..........  subcap jitters and flicks are fixed in 2018.12.2 - not sure when coming but will let you know.
  • Thu, Feb 7 2019 9:55 PM In reply to
    • sealke
    • Joined on Fri, May 25 2007
    • Posts 39
    • Points 465
    Great! Thanks for the info Marianna.
    Mac Book Pro Retina, 2,3GHz, 16GB, OSX 10.11.6, MC 2018.11/8.8.3 [view my complete system specs]
