Latest post Thu, Feb 14 2019 9:57 PM by cls105. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Jun 21 2018 8:58 AM
    • AlexisK
    • Joined on Thu, Jun 21 2018
    • Posts 4
    • Points 70
    Flickering/Jumping SubCap on Composer 2018
    Hi everyone !
    I'm on a documentary feature film in which we need english subtitles to broadcast it before making the final subtitles. It's edited on the version Avid Media Composer 2018.4.0.
    The editor used a LUT 3D as a specific video track on the whole timeline, and above stand the SubCaps track.
    In a inexplicable way, some of these subcaps are shaking, even jumping (like briefly changing position from down to middle screen, for about 1 frame time)... and it's random - or more precisely, some of them are jumping, then I replace it by another bit of SubCap, it stops, then it begins again...
    I tried to invert tracks (LUT/Subs) and it changes the moments of jumping, but doesn't cancel it !
    (For sure I already checked that there wasn't any keyframe on the subcaps position... I also tried to make a video render before screening... every move seems to change something, but everytime in a random way)
    Thanks a lot !
    A
  • Tue, Sep 4 2018 5:18 PM In reply to
    Re: Flickering/Jumping SubCap on Composer 2018
    Media composer 2018.7.1, same problem.
    Did anyone find a solution fo solving this problem?
  • Wed, Sep 12 2018 8:31 PM In reply to
    • AlexisK
    • Posts 4
    • Points 70
    Still no... The only one I got is to make an export, then go back on an older version of Avid and make them there...
  • Sun, Sep 23 2018 9:02 AM In reply to
    I found the solution for this bug. I observed that it didn't flicker when I have 2 raws in subcap, it is flickering only when I have only one, so on the empty row if you press space ( like an ascii invisible character) it solves the problem.
  • Mon, Sep 24 2018 8:21 PM In reply to
    • Posts 10,214
    • Points 218,175
    Alex and Gabi....
    I am having support check this for you both.....
  • Fri, Oct 26 2018 12:40 PM In reply to
    • Tim
    • Joined on Mon, Sep 12 2016
    • Posts 10
    • Points 130
    YES! That works like a charm. Thank you so much for this workaround. I was starting to go crazy.
    Why is this still not fixed?!
    AVID MC 2018.9 symphony option / Blackmagic Intensity Pro 4K / Intel Core i7-7700K @ 4.2ghz / 32 gb ram / NVIDIA GeForce GTX 970 / Windows 10 pro / [view my complete system specs]
  • Fri, Oct 26 2018 1:12 PM In reply to
    • Posts 10,214
    • Points 218,175
    Tim:
    Because the engineers havent pin pointed exactly what in code is causing it.  They are working on it though.
  • Thu, Dec 6 2018 9:08 PM In reply to
    Still toruble shooting this issue, having the 2 rows in subcap and it being renedered is the fix?
  • Thu, Feb 7 2019 5:22 PM In reply to
    • Posts 10,214
    • Points 218,175
    Hey everyone......
    The subcap jitter is fixed and will be released in 2018.12.2
    Not sure when that is coming but I will let you know.
  • Wed, Feb 13 2019 9:14 PM In reply to
    • danny
    • Joined on Sun, Jan 24 2010
    • Posts 67
    • Points 840
    I love supcap and have cut many subtutle jobs with it. I can confirm I had the jittery issue on 2018.12.1 and have reverted to 8.9.1 for now. However, my concern is (and always has been actually) that the black outline surrounding the letters, can be inconsistent in its width and angle. Sometimes it looks fine, other times it just looks a bit wonky - almost turning into a drop-shadow, rather than a thin, even black outline. I notice it can even change, depending on how many characters are in a line - sometimes just adding a character, or removing a punctuaction mark, changes the shape of the outline for the whole line. Has anyone else noticed this...?
    Also, I would love it if the fixing guys could work towards increasing the size of the text entry box - it's really difficult to read and edit!
    Danny
    Mac 3Ghz 8-core cylinder Xeon E5. 32GB 1866Mhz DDR3. AMD D700 graphics x2. OS 10.12.6 with MC/Symphony 8.9.1 and MC2018 [view my complete system specs]
  • Thu, Feb 14 2019 9:57 PM In reply to
    • cls105
    • los angeles
    • Posts 432
    • Points 5,610
    Really looking forward to this release because my subcaps are jumping like crazy.
    thank you
    MC 2018.12.1, diy x299 7940x 4.7ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
