Latest post Thu, Oct 25 2018 8:44 PM by cls105. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Jun 1 2018 4:16 PM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Runtime error while rendering a timeline
    I have started getting this error, which kills MC, while rendering a timeline. it seems to always happen on effect 41 of 63 (although I don't know which effect that is). Mostly it is rendering colour correction and LUTs. Three times in a row now and it is getting boring.
    Any ideas?
    matt
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 390.77) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Fri, Jun 1 2018 5:06 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    Re: Runtime error while rendering a timeline
    You may want to run a RAM test on your PC, also, I image you are running the correct GPU driver?
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Fri, Jun 1 2018 5:20 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Since posting earlier I have re-booted PC and have successfully rendered timeline in batches (to see if there was an effect causing the problem), but it all went OK.
    Im on driver 377.11, which seems to be highest I can do with my Quadro4000 and Windows 7 (am saving up for a new one).
    Odd you should mention memory - I have long since suspected this machine has some deep rooted problems. Frequently have to boot it twice to get all the services started. Sometimes the display fails to come alive, sometimes it is stable for a few minutes and then reports that the display driver stopped but then recovered. I have assumed it was memory on the Graphics card.
    I plan to upgrade to Win 10 after this project gets signed off. - see if that helps
    Matt
    Matt B
  • Fri, Jun 1 2018 7:11 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    OK, all fans are running, especially on the graphis card? Time for a compressed air cleaning?
  • Fri, Jun 1 2018 9:25 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 467
    • Points 5,505
    always keep a working image of your sytem drive.
    i'd say RAM would rather cause bluescreens. i'd look at drive / sata drivers
    chkdsk /f
    view event logs -> windows -> system
    have a glance at hhd led when funny stuff happens.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Sat, Jun 2 2018 12:45 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    TVJohn - All good suggestions -  Yes checked all the fans are running. I give it a blast of air every so often and it is reasonably dust free. I will check memory, although I suspect Graphics card or System drive giving notice.
    Lukas - Imaging system drive as I type. I thought I did that regularly too, but when I checked the last time was in 2014!!
    maybe the excuse I need to get a SSD system drive.
    Will report back with results. Thanks both for advice.
    Matt
    Matt B
  • Sat, Jun 2 2018 12:51 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 467
    • Points 5,505
    drop everything and get an ssd immediately.
    like you should have done years ago.
    sorry for scolding you, but you deserve it right now Wink
  • Sat, Jun 2 2018 1:10 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    OK, OK.
    SSD on order!
    And graphics card - see you have GTX1070 how do you find it? I was looking at Quadro P4000 but it is expensive.
    Matt
    Matt B
  • Sat, Jun 2 2018 2:09 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 467
    • Points 5,505
    good boy.
    yeah, gtx 1070 serves me very well. handles everything with ease, no hickups
    never even matched the driver tbh.
    look for a version that pushes the warm air out of the case.
    i think the "reference design" does, or something with pre-installed watercooling.
  • Mon, Jun 4 2018 12:28 PM In reply to
    Hi Lucas
    Drop everything and get an ssd immediately.
              How about M.2 PCIe SSD - making a build with one right now intend  putting the W10 operating  system on it .
    the one I chose is Apacer SSD Z280 .. great are the expectations .. they tell me the future is PCIe once they release suitable capacity at an afffordable price .. it's an expeiment with Flash Drive for the OS  and SSD'S for everyhing else .. cheers
    PS .. still following your posts after all these years .. Cheers
  • Mon, Jun 4 2018 1:13 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 467
    • Points 5,505
    sata vs pcie doesn't matter for OS.
    OP can't install pcie in his legacy machine.
    but yeah, pcie ssds have better sustained read/write rates.
  • Thu, Oct 25 2018 1:31 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    OK - machine now upgraded with SSD, windows 10 and P4000 graphics card and blown-out with compressed air and all fans'a'spinning.
    Still getting Runtime errors and MC locking up (not whole PC), I can usually restart MC and pick up projects from most recent save, but loose any subsequent work.
    Still on the lookout for suggestions.
    Matt B
  • Thu, Oct 25 2018 1:51 PM In reply to
    • cls105
    • los angeles
    • Posts 405
    • Points 5,215
    1) AVID FX gives me this error.  Try removing your plugins from the avx folders (move them temporarily).
    2) Your screen shot looks like you have desktop compositing enabled which isnt reccomended.  Run ASDT (google it, download it, run it, fix the flags).
    3) I can't believe people convinced you to get a new GPU for that old computer.  They don't do that much in Avid.
    4) Use Win 10.  I think 1703 is the supported release
    5) When I install win10 i generarlly don't have it hooked up to the internet until I install and run stopupdates 10... It will prevent windows from installing updates.
    MC 2018.12.1, diy x299 7940x 4.5ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Thu, Oct 25 2018 2:30 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Hi - thanks for the response. Most of your suggestions I have already done. I do suspect Boris Red (i dropped Avid FX) which is a bore because I use it a lot.
    Desktop compositing IS recommended for MC 8.6.2 and newer, but I have run ASDT anyway and fixed ant red flags = there were only a couple.
    This old (and faithful 'till this issue) is due for replacement imminently. The GPU will get re-deployed in due course.
    I am running Windows 10 pro although version 1803 and I do prevent automatic updates.
    MattB
    Matt B
  • Thu, Oct 25 2018 8:44 PM In reply to
    • cls105
    • los angeles
    • Posts 405
    • Points 5,215
    I wrote a message how disabling gpu solved many of these but im stil crashing.
