Latest post Tue, May 15 2018 2:30 PM by DStone. 5 replies.
Page 1 of 1 (6 items)
  • Mon, May 14 2018 5:46 PM
    Import settings?
    A friend of mine (graphic designer) recently produced some generic titles for a company I am launching, and I wish to bring these into Avid (import, not AMA-link).  However, the options are different to what I am used to - see attached below. Also below is the media info of the MOV file my friend supplied.  As said, I want to bring this into Avid, add a sound effect, and keep to then later place at the beginning of future projects, therefore something that is framerate-friendly would be welcome.
    Can anyone recommend an appropriate import setting?
    Thank you,
    DC
    General
    Complete name                            : I:\Me\Flow, Part 2\Films\The Avenue Motion Picture Company\Oliver's Work\5. Animated Titles in AE\1. The Avenue MPC animated logo (clockwise) - animated.mov
    Format                                   : MPEG-4
    Format profile                           : QuickTime
    Codec ID                                 : qt   0000.02 (qt  )
    File size                                : 195 MiB
    Duration                                 : 1 min 4 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 25.5 Mb/s
    Writing application                      : Lavf57.75.100
    Video
    Format                                   : ProRes
    Format version                           : Version 0
    Format profile                           : 422
    Codec ID                                 : apcn
    Bit rate mode                            : Variable
    Bit rate                                 : 24.8 Mb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 FPS
    Color space                              : YUV
    Chroma subsampling                       : 4:2:2
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.479
    Stream size                              : 189 MiB (97%)
    Writing library                          : fmpg
    Language                                 : English
    Matrix coefficients                      : BT.601
    Audio
    Format                                   : PCM
    Format settings, Endianness              : Little
    Format settings, Sign                    : Signed
    Codec ID                                 : sowt
    Bit rate mode                            : Constant
    Bit rate                                 : 705.6 kb/s
    Channel(s)                               : 1 channel
    Channel positions                        : Front: C
    Sampling rate                            : 44.1 kHz
    Bit depth                                : 16 bits
    Stream size                              : 5.39 MiB (3%)
    Language                                 : English
    Default                                  : Yes
    Alternate group                          : 1
    Asus N55SF Notebook running Windows 10 Home Processor: Intel(R) Core (TM) i7-2670QM CPU @ 2.20GHz 2.20GHz Installed memory (RAM): 8.00 GB System type... [view my complete system specs]
  • Tue, May 15 2018 9:16 AM In reply to
    Re: Import settings?
    Hi, can anyone please suggest a good setting? Genrally, what do the options displayed offer?
  • Tue, May 15 2018 10:51 AM In reply to
    Just link.
    iMac i5 27", 24GB RAM, OS 10.11.6 with Symphony 8.10., BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.12.5 with MC 8.10 and BMD Ultrastudio... [view my complete system specs]
  • Tue, May 15 2018 10:56 AM In reply to
    I could, but would rather bring it in properly.  Any suggestions on preferred import settings?
  • Tue, May 15 2018 11:35 AM In reply to
    These days, 'properly' usually means link, then transcode.
  • Tue, May 15 2018 2:30 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,455
    • Points 44,530
    Like everyone else says, link then transcode. When you import, it transcodes to DNxHD anyways.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
