Latest post Fri, Dec 21 2018 3:38 PM by Marianna. 14 replies.
Page 1 of 1 (15 items)
  • Mon, Apr 9 2018 3:25 PM
    • Rob
    • Joined on Thu, Nov 11 2010
    • NYC
    • Posts 83
    • Points 1,065
    2018.4 - Nitris DX Box not working
    Hi, I just did a reinstall of 2018.4. But the software is not recognizing the Nitris DX box.
    It was working fine right before the update.
    any suggestions?
    MC 7 Nitris DX Z800, 12 GIGS, Windows 7, SP1 [view my complete system specs]
  • Mon, Apr 9 2018 3:53 PM In reply to
    • JCBond
    • Joined on Sat, Mar 11 2006
    • Van Nuys CA, USA
    • Posts 109
    • Points 1,145
    Re: 2018.4 - Nitris DX Box not working
    You need to install the Avid DX driver. This no longer installs automatically. See the release notes.
    System 1: Symphony Nitris DX - HP xw8600 8xCores - Windows 7 SP1 64 bit. System 2: Symphony Nitris DX - HP xw8600 8xCores - Windows 7 SP1 64 bit. System... [view my complete system specs]
  • Mon, Apr 9 2018 4:06 PM In reply to
    • Rob
    • NYC
    • Posts 83
    • Points 1,065
    There it is,
    Thank you!
  • Tue, Apr 17 2018 4:08 PM In reply to
    • Steve111
    • Joined on Tue, Apr 17 2018
    • Posts 3
    • Points 45
    Hi Rob
    did you manage fix your Nitris dx issue, if so how?
    Cheers
    Steve
  • Wed, Apr 18 2018 2:52 PM In reply to
    • ramz434
    • Long Island
    • Posts 192
    • Points 2,395
    Inside the Programs folder on your C drive - go to the Avid folder. Once there go into UTILITIES and then DXDRIVERS. There are 2 verisons in there - Win 7 and Win 10. I did this after updating, and didnt need to do an uninstall first. Install, then restart PC.
    - HP Z400/24gb ram/Windows 10/MC8.9.4/256gb Samsung SSD/ NVidia GTX 1080/HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.13/MC8.9.4/NVIDIA GeForce... [view my complete system specs]
  • Wed, Apr 18 2018 3:53 PM In reply to
    • Steve111
    • Posts 3
    • Points 45
    Hi ramz434
    thanks for the reply, that's brilliant, all sorted and back to work.
  • Sat, Apr 21 2018 1:31 PM In reply to
    • Rob
    • NYC
    • Posts 83
    • Points 1,065
    Hey Steve,
    Yes, I was able to get it to work.
    Thanks!
  • Mon, Apr 23 2018 3:31 AM In reply to
    • Harry Invision
    • Joined on Wed, Feb 3 2010
    • Brisbane, Australia
    • Posts 93
    • Points 1,125
    Thank you,
    Did the same...should read the readme more carefully...after restart...
    Media Comoposer 2018.4 + Symphony DX Nitris HP Z840 E5-2659 Quadro P4000 32Gb of Ram Win 10 64bit 64TB Editshare 16TB Internal Raid [view my complete system specs]
  • Thu, Aug 23 2018 6:31 PM In reply to
    I installed the driver, but still no Nitris on the MC software. Any ideas what could I be doing wrong?
    HP Z840 Windows 10 Samsun 840 SSD 128 GB Ram GFORCE GTX Titan Black 160 TB DDP over 10GigE [view my complete system specs]
  • Thu, Aug 23 2018 6:50 PM In reply to
    • JCBond
    • Van Nuys CA, USA
    • Posts 109
    • Points 1,145
    Did you install the correct driver? I see you are on Windows 8, There is a driver version for Windows 7 and one for Windows 10. I am not sure wich one works on Win 8 but one of the two does.
  • Fri, Aug 24 2018 11:21 AM In reply to
    • Steve111
    • Posts 3
    • Points 45
    Victor I have the same issue every time I restart, my fix is to remove before reinstalling the driver,
    from the installer - click the remove driver option (not repair) and then back to the installer and reinstall.
    Good luck
  • Fri, Aug 31 2018 3:54 PM In reply to
    I have installed/Removed/Re-installed the driver several times.  Still can't get MC to recognize the Nitris DX.  Computer now comes back with this note:
    "Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)"
    and
    "This device isn't using any resources because it has a problem."
    Any Help would be appreciated.
    Dell, Windows 7 64 SP1, Dual Xeon 8 core, 24G nvidia
  • Sat, Sep 1 2018 5:38 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,486
    • Points 64,375
    Do not uninstall the driver from the Windows Control Panel, go to the Device Manager instead, remove it and reinstall.
    Symphony 2018.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Fri, Dec 21 2018 3:20 PM In reply to
    Same trouble for me, it appear that Windows was missng a KB to support SHA-2 Driver Signing Code, updating windows with KB4022168 and now it works well.
    This link help me to find this workaround:  https://avid.secure.force.com/pkb/articles/en_US/troubleshooting/DNxIO-drivers-are-not-digitally-signed-driver-error
    Good Luck!
    HPZ820, Dual Xeon 8 Core, Windows 7 64SP1, Nvidia Quadro 4000, 16Go
  • Fri, Dec 21 2018 3:38 PM In reply to
    • Posts 10,079
    • Points 216,495
    Glokenspiel:
    Good Luck!
    Good to know... thanks Big Smile
