Latest post Sat, Apr 13 2019 4:26 PM by Bruno M. 2 replies.
  • Fri, Mar 30 2018 6:35 PM
    • Aren Hansen
    • Joined on Tue, Mar 15 2016
    • Toronto
    • Posts 33
    • Points 375
    ScriptSync - moving Takes on a Slate
    Often I've added a few takes to scriptsync and realize later I need to add another one. Unfortunately, it's always placed last on the slate, regardless of when it was shot or how it's labeled. I can't figure out how to move them. Is there a way?
    A
    iMac (Retina 5K, 27-inch, 2019) 3.6 Ghz Intel Core i9 and 72GB Ram Vega 48 Intensity Shuttle Thunderbolt OWC Thunderbay [view my complete system specs]
  • Thu, Apr 11 2019 9:34 PM In reply to
    • JSosnovsky
    • Joined on Sat, Dec 29 2018
    • Posts 1
    • Points 15
    Re: ScriptSync - moving Takes on a Slate
    I have the same issue. Looking to move or re-organize takes on a grouped Slate....
  • Sat, Apr 13 2019 4:26 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 576
    • Points 7,370
    I've not found a way as of now, but I discovered if you show the 'Take' column in the bin view for your clips, and then fill-in take numbers for your master clips, they'll show up in the script.
    You'll see them in the little box below each take. Just make sure you keep the numbers to only two digits max.
    Doesn't help with re-ordering, but helps to see which take is which, if you do end up adding them out of order.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
