Latest post Fri, Mar 23 2018 4:22 PM by dbiok. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Mar 21 2018 4:28 PM
    • markle77074
    • Houston
    • Posts 332
    • Points 4,405
    Has Avid fixed the linking to Sony F-55 Raw files yet in the latest 2018 version?
    I can't link to Sony RAW files from my Sony  F-55
    I have several machines. My latest is a zbook with maxed out processor, memory and video card running windows 8. [view my complete system specs]
  • Wed, Mar 21 2018 4:57 PM In reply to
    • dbiok
    • Joined on Fri, Mar 19 2010
    • Germany
    • Posts 44
    • Points 520
    Re: Has Avid fixed the linking to Sony F-55 Raw files yet in the latest 2018 version?
    Hi there,
    do you have the "nablet SONY RAW AMA Plugin" installed? You have to install this on your own. It will not be installed with MC. Every version below 4.5.3 is not combatible with the MC 2018.x releases.
    There is nothing to fix for AVID. This problem is on the Sony/nablet side!
    so long & thx
    dbiok
    [3x MediaComposer 2018.7 @ NitrisDX || HP Z800 Workstation (Dual XEON X5570) || Win10 64Bit] - [1x Symphony 2018.7 @ NitrisDX || HP Z800 Workstation (Dual... [view my complete system specs]
  • Fri, Mar 23 2018 4:02 PM In reply to
    • markle77074
    • Houston
    • Posts 332
    • Points 4,405
    Do you know how to uninstall the old plugin?
  • Fri, Mar 23 2018 4:16 PM In reply to
    • markle77074
    • Houston
    • Posts 332
    • Points 4,405
    I saw that you can uninstall the plugin under Programs and Features.  I did that and installed the new Nablet Sony Raw plugin, and it will not link to Sony RAW files from the Sony F55
  • Fri, Mar 23 2018 4:17 PM In reply to
    • dbiok
    • Germany
    • Posts 44
    • Points 520
    Windows10:
    controlpanel -> Apps -> scroll down to "nablet...." -> uninstall
    or if you are upgrading from an older MC version and therefore old Sony-Plugins
    controlpanel -> Apps -> scroll down to "Sony AMA...." -> uninstall
    This is just a standard software install/uninstall, as you will do it with every other software.
    If you're on the old Sony-Plugins you have to make sure that you uninstall them, before you install the nablet-Plugins. They can not coexist!
    so long & thx
    dbiok
  • Fri, Mar 23 2018 4:22 PM In reply to
    • dbiok
    • Germany
    • Posts 44
    • Points 520
    How do you link them?
    Make sure to link the whole "magazine" not the files themself. I often get errors when I try to link only a single file out of the package, but never got any error, when I link the whole card. Just select the "XDROOT" (or whatever the root is called, cause I am not sure about the namingconvention of the F55) in the sourcebrowser and klick on link.
    For singlefile link:
    This is a bit confusing, because when you try to link a singlefile you have to make sure that the correct plugin was selected. You can rightklick in the sourcebrowser on the plugin-column of the file and set the plugin yourself. Make sure it is called "nablet SONY RAW..."
    so long & thx
    dbiok
