Latest post Sun, Apr 7 2019 8:40 PM by Ronald Czarnecki. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Mar 18 2018 12:59 AM
    Crash on Full Screen
    I just updated to the new 2018.2 with a clean install that support was helping me on. I created a new user profile. Everything is fine except when I go to full screen nothing plays and then it crashes. I did not have a problem before upgrade to 2018.2 with this system.
    I tried admin user, reboot, color space change Ycbcr 709 and RGB 709, on settings/full screen playback I have left 0, right 1920, top 0, bottom 1080. am I missing a settings with this new install?
    MC Version: 2018.2 System: PC windows 7 Pro 64 bit, Workstation ATX mid Tower case, MSI Z87-G45 MBoard, 650 watt,Crucial M500 250GB SSD, Intel i7-4770K... [view my complete system specs]
    MC 8.4.5     Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface  Pro Tools MP
  • Sun, Mar 18 2018 9:25 AM In reply to
    • mkj
    • Sweden
    • Posts 402
    • Points 5,270
    Re: Crash on Full Screen
    ask support to upgrade your computer to Win 10. Everything gets better!
  • Sun, Mar 18 2018 2:29 PM In reply to
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 473
    • Points 6,425
    I am getting the same think on my edit 1 system with MC 8.10. Although not on my laptop system (edit 3 in specs). I suspect the Nvidia Driver, which in both cases is version 377.11.
    I am in process of upgrading edit 1 to MC 2018.3, but having read your post I suspect it won't fix the problem.
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 411.95) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Sun, Mar 18 2018 5:39 PM In reply to
    Window 10 would probably be better but everything was fine until the upgrade.
    I hope to touch base with Avid Support Monday but curiousy what is an edit 1 system?
  • Sun, Mar 18 2018 6:15 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,425
    I have three editing computers; I call them edit 1, edit 2 and edit 3. 🙂
    Matt B
  • Wed, Mar 21 2018 1:46 AM In reply to
    Avid support had the answer and it was first the graphics card latest update 385.08 and then the settings. They said it should be:
    Can you try this next:
    Go to the NVIDIA Control Panel (by right clicking on desktop):
    - Under Manage 3D settings > Global Settings > Use Base Profile and select Prefer Maximum Performance for the Power Management Mode
    - On the Program Settings tab > Select Avid Media Composer > CUDA - GPUs, select "Use These GPUs" and then check Quadro K2000D
    - Open GL Rendering GPU > Quadro K2000D
    - Power management mode > Prefer maximum performance
    - Threaded optimization > on
    - Triple buffering > on
    - Vertical sync > on
    Then launch Media Composer and check.
  • Wed, Mar 21 2018 10:37 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,425
    Thanks Ronald - I will try these settings out on my current driver (v377.11), I tried to update to 385.08 already but got an error that my card was not compatible, it is a Quadro 4000, presumeably too old!
    Matt B
  • Fri, Jul 20 2018 9:19 AM In reply to
    • Freddy
    • Joined on Sun, Nov 5 2006
    • Sweden
    • Posts 254
    • Points 3,035
    Don't forget to enable Desktop Composition in Windows (with newer MC versions)
    I can see a lot of "crashes" related to incorrect settings.
    http://avid.force.com/pkb/articles/en_US/How_To/Enable-Desktop-Composition-in-Windows
    http://www.freddylinks.com <-- Find EVERYTHING Avid and Tutorials there. Probably the most comprehensive Avid only webpage with over 2000+ Links to Avid Video Tutorials and Avid Information for Media Composer, NewsCutter, Symphony, Interplay, ISIS, Unity MediaNetwork, ProTools, Avid Artist Series. Completely free of fees, registrations, and ads.
  • Fri, Jul 20 2018 11:56 PM In reply to
    I am now using Premiere more and more just too many tech support calls, not enough work getting done.
  • Sun, Apr 7 2019 7:14 PM In reply to
    Hi Ronald,
    these settings helped me with the same problem, thanks for sharing :)
    HP Z420 MC 2018.12.3/2018.18.2/7.0.4 MINT server-client network [view my complete system specs]
  • Sun, Apr 7 2019 8:40 PM In reply to
    I gave up on Avid I do Premiere only now. However I saw I had a weak solid states drive that was affecting the processor maybe it was the C drive and it's solid state.
