Latest post Tue, Jan 30 2018 8:47 AM by BenoitM. 4 replies.
  • Mon, Jan 29 2018 2:46 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    how to optimize program track CC on Symphony timeline with filler
    Pretty urgent:
    I have a long track containing mixed PiP media, some being regular video clips, some being stills (using BCC Pan & Scan).
    When I apply a Prog Track CC, the segments containing still images (BCC P&S on filler) are NOT corrected (seems to be in line with the documentation).
    I there a simple workaround, a way to CC the whole track at once (or quickly) i.e. without adding a CC effect to every still segment on the track (there are many of those) ? Since this is a PiP track, the underlying track should not be affected.
    Suggestions ?
    MC 2018.12 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (10.11.2.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32... [view my complete system specs]
  • Mon, Jan 29 2018 10:07 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,346
    • Points 40,445
    Re: how to optimize program track CC on Symphony timeline with filler
    Well, I would save the the color effect in a bin, then select all the clips on the track in question (select in to out / no filler button) and then double click the saved color effect.  This should apply that effect to all the selected clips.
    Jef
    Jef Huey
  • Mon, Jan 29 2018 10:32 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    Yep, but unfortunately this replaces any existing effect on the target clips; AFAIK it is not possible to ALT-double click to apply on top (nest) of mutiple clips at once ?
  • Mon, Jan 29 2018 10:44 PM In reply to
    • jef
    • Maryland
    • Posts 3,346
    • Points 40,445
    Yes.  You are correct.  No more than one effect with that trick.
    I got nothin else.
    Jef
    Jef Huey
  • Tue, Jan 30 2018 8:47 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    OK -- too bad Prog Track CC doesn't apply to filler...will roll up my sleeves now ;-)
