Latest post Sun, Jan 21 2018 2:40 AM by Telegram!. 4 replies.
  • Fri, Jan 19 2018 6:14 AM
    • 2uantumKid
    • Joined on Fri, Jan 19 2018
    • Posts 2
    • Points 40
    How to apply audiosuite effects to specific segments
    Hello,
    I'm new to both Media Composer First and video/audio editing in general. I've tried looking at the documentation for this problem, but haven't found a solution.
    I'm trying to apply the TimeShift effect in the AudioSuite to a segment of an audio track, but whenever I apply it, it is done to the entire track. I've tried marking a portion of the track with the In/Out markers but to no avail, so I think I'm misunderstanding how the In/Out markers work. Is there also a way to apply the TimeShift effect so that it is gradual? In other words, lets say I wanted to slow down a track by 50% but I want it to to descend down rather than being applied all at once.
    Thanks for the help and assistance.
  • Fri, Jan 19 2018 4:23 PM In reply to
    Re: How to apply audiosuite effects to specific segments
    An Audio suite effect will apply to a whole clip. So you need to add edits to your audio track to create a seperate section. Then the Audio suite effect will aplly to just that section.
    ACI Moderator. I'm not employed by Avid or work for them. I just do this in my spare time. Symphony V8.6 / 8.3.1 HP Z400 system [view my complete system specs]
  • Sat, Jan 20 2018 9:08 PM In reply to
    • 2uantumKid
    • Posts 2
    • Points 40
    Thanks for help, that was my suspicion. Is there a way to apply TimeShift as a progression? Like instead of slowing an entire clip down by 50%, having it slow down gradually?
  • Sat, Jan 20 2018 10:15 PM In reply to
    I don't think you can keyframe Audio suite plugins. You could break the clip up into lots of clips and then stagger the timeshift in each clip.
  • Sun, Jan 21 2018 2:40 AM In reply to
    2uantumKid:
    http://www.avid.com/plugins/vari-fi-audiosuite
    (no idea if this is part of your FIRST stock FX, if it can even work outside of ProTools, but it sells for $7.99 and requires iLok2, it says)
    If you can run the third-party software called AUDACITY, a popular, freeware Audio program, you can accomplish that "powered-down turntable" effect very quickly and with a minimum of effort.
    After loading your audio into Audacity, it involves ADDing something called a "Time Track", then setting a range (100% or more to maybe as low as 0%) and then manipulating key frames with something they call the Envelope tool, inside that Time Track. Very point and click.
    Then Exporting a WAV or if you have Audacity set up for it, an MP3.
    There's certainly as way, in AVID, to build a whole bunch of Pitch-adjusted master clips... but it's not as simple to accomplish and perhaps not as smooth at transitions.
    Win 7 Pro; HP 820z, 16GB ram; Composer Nitris DX, Squeeze v8.5 Pro _____ Also:___ Windows 7 Pro x64 Dell T3400 workstation E8400 3.0 Ghz 4GB Ram,... [view my complete system specs]
