Latest post Wed, Mar 21 2018 1:44 AM by Ronald Czarnecki. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jan 9 2018 6:42 PM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Full Screen Playback in MC8.10
    I have just returned my Edit 1 PC to Windows 7 (clean install,it was windows10; but I was having problems). Then I went to a clean install of MC8.10.
    Just in the process of setting up my user profiles and discovered that invoking 'Full Screen Playback' just causes both monitors to go black. Windows task bar is still visible and I can launce the Task monitor, which reports that MC is not responding. I can end the task and re-launch MC.
    Any ideas?
    MattB
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 390.77) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Wed, Jan 10 2018 6:37 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Re: Full Screen Playback in MC8.10
    OK. Don't worry - seems to have fixed itself!!
    Matt B
  • Thu, Jan 11 2018 4:36 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 465
    • Points 5,475
    Fixed itself you say?
    i got my suspicions.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Thu, Jan 11 2018 6:43 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Yes
    Matt B
  • Mon, Mar 19 2018 11:24 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 470
    • Points 6,390
    Its gone again!
    Matt B
  • Wed, Mar 21 2018 1:44 AM In reply to
    I just worked with support on the same problem and mine also worked one time and then would not go to full screen.
    Wound up bring the graphics card-- Quadro should be at  385.08 latest version
    Then go to Nvidia control Panel
    Can you try this next:
    Go to the NVIDIA Control Panel (by right clicking on desktop):
    - Under Manage 3D settings > Global Settings > Use Base Profile and select Prefer Maximum Performance for the Power Management Mode
    - On the Program Settings tab > Select Avid Media Composer > CUDA - GPUs, select "Use These GPUs" and then check Quadro K2000D
    - Open GL Rendering GPU > Quadro K2000D
    - Power management mode > Prefer maximum performance
    - Threaded optimization > on
    - Triple buffering > on
    - Vertical sync > on
    Then launch Media Composer and check.
    MC Version: 2018.2 System: PC windows 7 Pro 64 bit, Workstation ATX mid Tower case, MSI Z87-G45 MBoard, 650 watt,Crucial M500 250GB SSD, Intel i7-4770K... [view my complete system specs]
    MC 8.4.5     Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface  Pro Tools MP
