Latest post Sun, Jan 21 2018 2:36 PM by Marty. 4 replies.
  • Wed, Dec 13 2017 10:15 PM
    Dupe Detection glitchy in 8.9.4
    Hey all, can someone confirm dupe detection's spotty functionality in 8.9.4?  I was comparing some edits whilst prepping for color, and dropped something on track 3 that had duplicates but they didn't trigger DD... when I moved the clips onto track 1 the DD activated, when I moved the clips one frame left or right on track 3 it activated.... weird.
    Hackintosh OC'd 4.2 i7-1070 9GB-32 GB RAM-Solid State Boot-8x Fibre to Terrablock Currently running 10.13.4 Symphony 2018.9.0 [view my complete system specs]
  • Thu, Dec 14 2017 3:02 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,795
    • Points 19,825
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Dupe Detection glitchy in 8.9.4
    Hi Jason,
      I can't find your email address, can you pm me so I can start a support case.
    Update: opened a support case 03355416
    RalphC
  • Tue, Dec 19 2017 11:26 PM In reply to
    Ok, more info:
    I've tested it on 8.9.4 and 8.9.3... it has to do with clips requiring frame flex to resize down to your project settings.
    Create an HD project (my tests were all 23.98), take any type of file that's bigger than HD (QT, mxf, what have you) and AMA link the clips into a bin.  Load a clip into source, mark an in and out, and cut them into the HD sequence.  Now cut the same clip onto a higher track (I used track 3, leaving track 2 blank).  Turn on DD and you'll see there's no DD color warning.  Now, using a segment tool, move the top clip one frame in either direction and suddenly, DD appears.
    It's a frame flex thing.
    Jason
  • Wed, Dec 20 2017 1:26 PM In reply to
    • RalphC
    • Posts 1,795
    • Points 19,825
      Avid Employee
    I'm adding this to the case notes.
    RalphC
  • Sun, Jan 21 2018 2:36 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 916
    • Points 10,645
    Hello, did Avid Support find the issue?
    I'm also working with 8.9.4 and dupe detection sometimes disappears randomly, I don't use Frame Flex.
    It's a 1080p/25 project.
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
