Latest post Thu, Feb 15 2018 10:35 PM by Marianna. 55 replies.
Page 4 of 4 (56 items) < Previous 1 2 3 4
  • Mon, Jan 22 2018 11:55 PM In reply to
    • R Puru
    • Joined on Thu, Nov 12 2015
    • Posts 26
    • Points 300
    Re: ISIS500 upgrade failure.
    I've tried rebuilding the server with a supplied ISIS5000 image (Windows Storage Server) without any luck. I still have the same error in that the raid set fails to iniatlize by the installer:
    System event log viewer shows: Warning after 5 attempts the product type is still UNKNOWN. Is there anymore information on the Raid controller interms of software/firware version, raid card type/models, slot config etc?
  • Wed, Jan 24 2018 4:30 PM In reply to
    • cazzimir
    • Joined on Wed, Feb 25 2015
    • Paris
    • Posts 11
    • Points 155
    HEllo,
    What was the ISIS version prior to the upgrade ? ISIS 4.1 ? 4.2 ?
    Cause after ISIS 4.5 or If the product number is not set or set incorrectly,RaidConfig is regarded to fail.
    (wich seems to be the case )
  • Wed, Jan 24 2018 11:06 PM In reply to
    • R Puru
    • Posts 26
    • Points 300
    Thank you for your reply. This indeed sounds like the exact problem that i'm having. Where/how do I correct this?
    I've reinstalled ISIS 4.0.3 (4.2 client) and everything works as I expect. The problem is definately to do with this product type. The old hdraid.exe reports the same error, but assumes it's US_TYPE_ISIS5000 and continues to setup and work properly. See here:
    As soon as I try to install 4.5 or above, i'm back to the same error and it fails to setup or continue. See here:
  • Thu, Jan 25 2018 9:07 AM In reply to
    • cazzimir
    • Paris
    • Posts 11
    • Points 155
    Open a support case explaining you problem:
    "ISIS5000, during an upgrade to 4.7 Raid Set configuration status is error/warning.
    In the event log, there is an error message saying "Avid ISIS Raid configuration tool could not be found". Product server type could not be determined from part number 7030-30044-75"
    The only way To fix the error, his to re-enter the PN  using an USB bootable key
  • Thu, Jan 25 2018 10:38 AM In reply to
    Hi Cazzimir,
    Do you know if this is documented anywhere?
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Thu, Jan 25 2018 10:17 PM In reply to
    • R Puru
    • Posts 26
    • Points 300
    cazzimir:
    Ouch! ok thank you for the info. Have you done this personally or have you heard of another instance where this has happened? I'll use this info to give to Avid to support my case Yes
    Jeroen van Eekeres:
    Hi Cazzimir,
    Ditto.
  • Fri, Feb 9 2018 11:34 AM In reply to
    • cazzimir
    • Paris
    • Posts 11
    • Points 155
    Hello,
    Sorry for the delay,I was off with no internet connection...
    I had this case once when replacing the riser card  of a ISIS 5000
    I guess it's not documented,normally you just need to re image the ISIS to make it working again..
    I guess the support will and find the case number 02319025
    Smile
  • Sat, Feb 10 2018 7:29 PM In reply to
    cazzimir:
    That makes sense
    Jeroen van Eekeres
    www.mediaoffline.com
  • Sun, Feb 11 2018 10:48 PM In reply to
    • R Puru
    • Posts 26
    • Points 300
    cazzimir:
    Come to think of it, I beleive we had a risers replace in these chassis too back in 2013 when they were oringinally purchased for The Great Gatesby. It was part of some product recall or possible issue when upgrading there was risk of losing the raid IIRC. Thank you again.
  • Wed, Feb 14 2018 2:29 AM In reply to
    • R Puru
    • Posts 26
    • Points 300
    I can finally put this issue to rest!
    Basically,  when the riser cards in our chassis were replaced, the technician failed to complete the install process. The last step (as cazzimir pointed out) involves booting from a USB stick in combination with Avid supplied files. This enables you to change the Part number to the correct version, in order for RaidConfig.exe to work correctly.
    In my case, because both chassis have been out of hardware assurance since 2016, Avid online simply referred me to the local reseller. I would say they did that because they assume the reseller that upgraded this, should have done it correctly. In the end my local reseller opened a support ticket and got me the information and files that I needed. There is no reference to these files online, that I have access too. Reseller and Current ACSR may have access to them? I have them backed up. if anyone in the future needs them, shoot me a message.
    I'd like to say a quick thank you to Jeroen for helping me work through this and also cazzimir who managed to chime in at the most crucial moment. Cheers to you guys!
    Rob Puru
    Spectrum Films
  • Thu, Feb 15 2018 10:35 PM In reply to
    • Posts 10,159
    • Points 217,400
    Our community is amazing and absolutely the best!
    Thanks Jereon and Cazzimir for helping Rob out!
