Latest post Thu, Nov 23 2017 1:44 PM by BenoitM. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Nov 16 2017 9:40 AM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,117
    • Points 13,490
    How to recover orphaned bin objects after crash
    When MC crashes between an object creation and the auto (or manual) save of the containing bin, the object is orphaned (doesn't appear in the bin after restart). I know how to recover media files like mixdowns etc. but is there a way to recover an customized effect that was stored in a bin just before the crash ? Is the orphaned effect laying somewhere "stranded" in a folder where I could recover it ?
    MC 2018.2 (Symphony option)/BCC 10.0.5/RED 5.6; Matrox MXO2 Mini (8.0.0); DELL Precision M4700 - Intel Core i7-3740QM 2.7 GHz - 24 GB RAM; nVidia Quadro... [view my complete system specs]
  • Sun, Nov 19 2017 10:04 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,274
    • Points 61,870
    Re: How to recover orphaned bin objects after crash
    You can't regain an effect preset You created if that preset hasn't been saved to a bin. You could recover a rendered effect, there is no way that I know of to associate it back to the relevant sequence though. The mediafile is not orphaned anyway, it belongs to the project, but it does not belong to the sequence, and will lie on the media drive like any other unused precompute, eg old renders of subsequently modified effects. You can fiddle with the 'Set bin display' options both in the media tool and in the target bin, and drag and drop stuff, don't know if this will take where You want to go; what are You trying to accomplish?
    Symphony 2018.5, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Sun, Nov 19 2017 1:49 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,117
    • Points 13,490
    Thanks for these comments.
    I assume an effect preset is an object that exists only in memory until the containing bin is saved (unlike media files and renders).
    So an app crash means: saved effect preset is lost without tracks on disk if the crash occurs before the bin was saved...I just wanted a confirmation.
    I was a bit tired of the number of unexpected crashes I had that day...not sure why...this ageing system was perhaps a bit short of RAM, so I cranked up from 20 to 24 GB and will see if I continue getting these crashes. In the meantime I'll remember to pres CTRL-S immediately after I save a complex custom effect preset Wink
  • Wed, Nov 22 2017 11:33 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,021
    • Points 12,550
    On a similar theme I have been getting a lot of crashes on 8.9.3 and although I can find say the last recorded voice over file in my MXF folders how do I get it back in a bin when that bin wasnt saved before a crash?  Finding it in media tool is easy but it wont drag it back into the bin.  I had to put it through Sorenson to unwrap it to a mov and import!
    MC 8.6.5, Blackmagic Intensity Pro (cant get it working in 4k though...), WIN 10 on 2000Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Thu, Nov 23 2017 9:08 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,117
    • Points 13,490
    try dragging the mdb file of that MXF folder into a temporary bin: when you see the media file you want, drag it from the temporary bin to the intended bin.
  • Thu, Nov 23 2017 10:03 AM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,021
    • Points 12,550
    Nope - wont go - cursor turns into the no entry sign...
  • Thu, Nov 23 2017 1:44 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,117
    • Points 13,490
    Here I can easily drag & drop a .mdb (NOT MXF !) file from an Avid MediaFiles folder to an empty bin and that populates it with the media files in that folder...
