Latest post Fri, Nov 24 2017 3:52 AM by jef. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Nov 14 2017 2:32 PM
    Enable Mask Margins, compromises 10bit image quality
    Using MC 8.8.5
    My media is DNx175X
    When I make an export using same as source and use "Enable Mask Margins", the export comes out as if it has been pushed through an 8bit process and does not retain the image quality of the original.
    Can anyone confirm this bug?
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Tue, Nov 14 2017 8:27 PM In reply to
    Re: Enable Mask Margins, compromises 10bit image quality
    Not on my end, all exports look as they should... obviously, you are making certain the quality setting on the timeline is the quality you want?
    Jason
    Hackintosh OC'd 4.9 GHz i7-7700k, AMD Radeon Vega 64, 64 GB RAM, SSD, 8x Fibre to Terrablock, BM SDI 4k, currently running Mac OS 10.14.3. Symphony... [view my complete system specs]
  • Fri, Nov 17 2017 3:01 PM In reply to
    Hi Jason.
    Are you on 8.8.5 or later?
    Not sure what you mean about making certain the quality. My timeline is set to full green 10bit. But that does not effect the export quality. I'm using same as source as my output.
    Do you have a good 10bit gradiant to test the result. Obviously you would only see the difference I am talking about on a 10bit external montitor.
    The output file reports as 175X but the image has definately been quantized.
  • Fri, Nov 17 2017 9:43 PM In reply to
    You're right that the Timeline Video Quality setting wouldn't affect an export but that's assuming if you had something needing a render, you had that switch set to the full green 10-bit, otherwise it would of course look low-res.
    I'm using an older Dreamcolor HP LP2480zx which is supposed to be a 10-bit monitor.
    I'm running MC 8.9.2 w/Symphony option on a MacPro running El Capitan.  I'm using a BlackMagic Decklink 4k card but monitoring HD-SDI to the dreamcolor.
    When I bounce between my SAS export (with Mask Margins enabled) re-linked to the source side, and my original timeline (with a gradient ramp I created in AE 16-bit) I see no difference.  I'm using DNX 175x for the import of the ramp, and as a codec for the export.
    Maybe you wanna send me your ramp file or something?
  • Fri, Nov 17 2017 10:41 PM In reply to
    I even rendered out a 32-bit float (that I brought in to AVID 10-bit DNx175X) and exported that... again, looks fine.  Can I send you a 5-frame test?  Also, just double-checking, when you are seeing the 'quantizing,' how are you looking at that?  Through QT?  Through your AVID?  Through something else?
  • Mon, Nov 20 2017 1:23 PM In reply to
    I'm doing everything on a10bit monitor through Artist IO.
    I export SAS once with mask margins on and once with them off.
    I import both files back in and cut them on tracks 2 and 3 of the original timeline. And I can visually see the difference between the nomask and mask. Maybe it's an exageration to say 8-bit quantizing, but you know how grads can show up every slight imperfection.
    On further testing I actually see that complexity of the image has an impact also.  A pure grad does not display it but my image is footage with a natural grad to the sky.
    I guess that 175X is not all that perfect. I just thought that simplifying an image by adding a mask would never result in quality loss but it does in certain circumstance.
  • Mon, Nov 20 2017 4:37 PM In reply to
    I'd expect adding a mask to improve quality. Your content does then contain less picture info as the mask is easy to compress.
    Necer been happy that x resolutions are the same datarate as non x. So for 10 bit you are using the same datarate as 8 bit but have 20% more bits to compress. The implication is dnx17x is more compressed than dnx175
  • Mon, Nov 20 2017 6:28 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,405
    • Points 41,085
    James@Seamless:
    I import both files back in and .....
    Just checking.  When you say "import back in, exactly HOW are bringing it back?  Classic import or Link?
    Jef
    Jef Huey
  • Mon, Nov 20 2017 10:20 PM In reply to
    jef:
    James@Seamless:
    Jef
    Its such a shame that folks still refer to import often actually as ingest.
    I don't think half dropping the term AMA helped.
    AMA link or import is a clear choice. But we need people to understand why they are so different.
  • Tue, Nov 21 2017 6:19 PM In reply to
    • jef
    • Maryland
    • Posts 3,405
    • Points 41,085
    Pat Horridge:
    jef:
    James@Seamless:
    Jef
    And that is why I suggested an Avid managed FAQ.  Good people on the list keep answering the same questions / problems over and over.
    Jef
    Jef Huey
  • Tue, Nov 21 2017 8:33 PM In reply to
    • Posts 10,204
    • Points 218,070
    jef:
    Jef
    Jef
    Agree and possibly can do this in my spare time :)
  • Thu, Nov 23 2017 2:25 PM In reply to
    • jef
    • Maryland
    • Posts 3,405
    • Points 41,085
    Marianna:
    jef:
    Jef
    Jef
    Funny. (said with ironic smile).  I would think your talented Moderaters could help (no irony here).
    You lead.  Your troops will follow.
    Jef
    Jef Huey
  • Thu, Nov 23 2017 10:12 PM In reply to
    • Susi
    • London, UK
    • Posts 578
    • Points 6,655
    I love this forum. Just sayin'...
    Media Composer 8.6.4 on 15" mid-2012 Macbook Pro (OSX10.11.6) 2.7GHz Intel, 8GB RAM Gizmos: CanonXF200; Canon 550D (DSLR); Hero Go-Pro3 and 4; Sony... [view my complete system specs]
  • Thu, Nov 23 2017 11:10 PM In reply to
    jef:
    [ironic gratitude] Golly, thanks Jef. [/ironic gratitude]
    A forum FAQ would be a full-time job. If you think that's an exaggeration, here's a link to the Licensing FAQ, which links to four documents, 13 Knowledge Base articles, and has a glossary of 13 terms before getting to the actual 22 questions in the FAQ, which are divided into 10 sections.
    And even if you limited it so it was the exact combination of comprehensive and useful, you'd still get repetitive questions from people who either skipped it or didn't know it was there in the first place. There are posts in all the introductory sections of each forum asking people to list system specifcations in their posts, but people still post without including them.
    Media Composer 2018.12.2 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Fri, Nov 24 2017 3:52 AM In reply to
    • jef
    • Maryland
    • Posts 3,405
    • Points 41,085
    camoscato:
    jef:
    Points taken.
    Using your example, I did not even know the Licensing FAQ existed!!  And I know that the Knowledge Base exists (sort of). Looking at the top of the this Forums page, you see Home, Blogs, Videos, Forums, etc.  But not Knowledge Base.
    Seems like a missed oportunity.  Maybe the Knowledge Base is really the FAQ that needs some advertisement love.
    Jef
    Jef Huey
