Latest post Sat, Nov 4 2017 3:08 PM by RalphC. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Oct 30 2017 4:52 PM
    Media composer stuck at reading user settings
    Hi
    I am using Media Composer 8.2 with interplay 3.1 and I have a problem while starting Media Composer.
    It got stuck at reading user settings
    Note :-Sorry I did this post in Mac section although I am using Avid media composer on Windows 7
    HP Z440 16GB RAM PROCESSOR : INTEL XEON CPU E5-1650 3.5GHZ WINDOWS 7 64 BIT NVIDIA QUADRO K2200 [view my complete system specs]
  • Mon, Oct 30 2017 9:26 PM In reply to
    • Posts 10,282
    • Points 219,150
    Re: Media composer stuck at reading user settings
    First can you add your specifications to your profile.  Click on your name in the right corner then edit profile and add spec's. Helps us help you.
    Second.......I would delete the MCState files.
    The MCState setting files can be found in two places:
    • the main Settings folder in the Media Composer application folder
    • in each individual User Settings folder
    The MCState found in the Settings folder remembers what user and projects were active the last time the application was in use. It also contains certain Console commands, such as Disble3D and in version 7.x, it remembers which video format was chosen for the 3D hardware.
    The MCState in the Users folder contains window views for each user. For example, a source or record window that is stretched or a particular timline view is saved in this file. It is necessary at times when troubleshooting to delete these files and have Media Composer rebuild them as they can become corrupt.
  • Tue, Oct 31 2017 7:31 PM In reply to
    Thanks Marianna for the reply actually I have a fresh copy of Windows 7 and the media composer and the relevant drivers/applications are up to date according to the avid guideline.and I also configured the media indexer path in the localhost.
  • Wed, Nov 1 2017 2:15 AM In reply to
    Where are the user settings stored? locally or on networked storage?
  • Sat, Nov 4 2017 6:16 AM In reply to
    user settings are stored locally.It's happening while launching the media composer with interplay/isis connected mode.Without it, it's launching in a good way.
  • Sat, Nov 4 2017 3:08 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,840
    • Points 20,340
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    I'm moving this to PC section.
