Latest post Sun, Dec 23 2018 11:35 PM by Adrian Redmond. 12 replies.
Page 1 of 1 (13 items)
  • Thu, Sep 14 2017 1:40 PM
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 491
    • Points 5,905
    Time for a "Replace Clip" button?
    When working on effects heavy timelines, what slows me down more than anything is how long it takes to replace a clip which has effects associated with it.
    With many effects I can step in an change the shot (which slows the Avid down in the processes).
    But with things like Symphony CC effects, Motion FX, Frame Flex, LUTs, Audio Suite, levels and EQ, there's no straight forward way to replace a clip.
    I've either got to save a preset and re-apply (ie: Audio Suite, Motion and CC) or write down the parameters and re-create the effect (ie: Audio levels, Frame Flex and LUTs).
    I think there should be keystroke like the Replace Edit command to simply Replace the Clip but retain the associated effects.
    Let me know your thoughts,
    Jake
    Media Composer 2018.9 MacPro 6 core - 32 GB RAM - OS:10.13.6 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Sun, Sep 17 2017 8:13 AM In reply to
    Re: Time for a "Replace Clip" button?
    Excellent idea, and a big time-saver.
    +1
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja I/O express, Apple... [view my complete system specs]
  • Sun, Sep 17 2017 11:32 AM In reply to
    Very good idea indeed. +1
  • Mon, Sep 18 2017 4:08 PM In reply to
    +1 +2
    Hackintosh OC'd 4.9 GHz i7-7700k, AMD Radeon Vega 64, 64 GB RAM, SSD, 8x Fibre to Terrablock, BM SDI 4k, currently running Mac OS 10.14.3. Symphony... [view my complete system specs]
  • Fri, Dec 8 2017 1:26 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,559
    • Points 65,185
    There's already a Replace edit command in MC, its button used to sit in the Composer window, between the Splice in and the Overwrite button, its place has been stolen by the Tool palette button long ago. Time to revive and improve it, in a 'multi effects friendly' fashion (or to redesign the way MC handles effects!).
    peace luca
  • Fri, Dec 15 2017 1:52 PM In reply to
    • hitINdaGs
    • Joined on Sat, Nov 3 2012
    • Posts 99
    • Points 1,255
    +1
    I posted this request twice already...
  • Sat, Jan 13 2018 12:24 AM In reply to
    • Doug Abel
    • Posts 35
    • Points 415
    +1.
    It's sort of analagous to a word processing prgram where you can "paste and match style" over existing text.  Sort of.
    Dg
  • Wed, Feb 21 2018 4:12 PM In reply to
    • apeshake
    • Joined on Wed, Mar 20 2013
    • Posts 13
    • Points 175
    I often layer up effects on the tracks above my source clips (like adjustment layers) so i can replace the source without digging down through nested layers but it is a faff (you have to add edits to all the filler tracks above before applying fx). This also helps out when avids getting confused about which effects to render and you end up manually rendering each one
    PS you mention audio suite - is there a way to layer audio suite clip effects that i've been missing all this time?
  • Thu, Feb 22 2018 12:05 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,559
    • Points 65,185
    apeshake:
    You've been missing it for a short while, nested audio suite effects is a recent addition. You can apply an audio suite effect, step into it and apply another one; I don't remeber how many of them You can add though.
    peace luca
  • Thu, Feb 22 2018 10:44 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,386
    • Points 97,010
    +1.  And while we're at it, the ability to mark in and out points to apply an effect without having to force timeline cuts.  You don't always need an effect to cover the entire clip.
  • Fri, Feb 23 2018 3:03 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,413
    • Points 41,200
    jwrl:
    You mean like Avid DS had ages ago?  Big Smile
    Jef
    Jef Huey
  • Fri, Feb 23 2018 11:42 PM In reply to
    • jwrl
    • Posts 8,386
    • Points 97,010
    Funny, that.  Or like Lightworks has now.
  • Sun, Dec 23 2018 11:35 PM In reply to
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 176
    • Points 2,465
    Nice idea - I'd go for that!
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-2640 6-core HT 2.5GHz CPU 32GB RAM NVidia Quadro K4000 Graphics on Win7x64... [view my complete system specs]
    Adrian Redmond
    Owner / Producer / Editor
