Latest post Wed, Sep 20 2017 4:24 PM by touviere7. 31 replies.
Page 2 of 3 (32 items) < Previous 1 2 3 Next >
  • Sat, Sep 2 2017 12:32 PM In reply to
    Re: Media Composer 8.9.1 now available...
    My Source Browser is messing about since the latest update!
    It's no longer either automatically selecting or allowing me to manually select a Plug-in for AMA linking....it's just saying "Not processed" under the Plug-in column. I'm working with buckets of archive material which have all been created the same way (exporting from a Quantel edit server) and have all worked fine up until now and all previously used clips are still telling me which Plug-in is being used.
    I'm trying to link h264 mov clips which all play fine using QT player outside MC.
    I have successfully managed to import a clip as a test but this isn't ideal with the amount of material I'm looking to use....and especialy as AMA has been working flawlessly up until now!!
    Anyone else out there finding this or similar?
    Intel Core i7-6900K 3.20Ghz, nVidia Quadro M4000; 32GB RAM; Windows 10 Pro 64; WD Black 2TB Performance HDD (7200 RPM SATA 6 Gb/s 64MB) for Media; WD... [view my complete system specs]
  • Sun, Sep 3 2017 12:23 AM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 169
    • Points 2,025
    wildbeastfilms:
    I had a similar issue in 8.9 - I could not link to Pro Res - so I went back to 8.8.5 - now everything is fine.  Seems 8.9 and 8.9.1 are very buggy - I willl be staying on 8.8.5 for awhile as my faith in these upgrades have diminshed.
    Symphony 2018.12 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Sun, Sep 3 2017 11:57 AM In reply to
    • ugo1
    • Joined on Thu, Jul 13 2006
    • Italy
    • Posts 266
    • Points 3,700
    HI,
    with the config below I still get some red (at the end of clip) and yelllow line (at the start of the clip) on the timeline with GH5 mov file. That effect the file output?
    Regards
    Ugo
    Case: Phantek Enthoo Luxe, Motherboard: Asus Prime X299 deluxe, Cpu: Core i9-7900K,Ram: 32GB Ripjaws 4, GPU: Asus Nvidia 1080, Sound card: X-Fi Forte... [view my complete system specs]
  • Sun, Sep 3 2017 1:33 PM In reply to
    Thanks for that. First time I've noticed a backwards step like this on upgrading for ages.
    Any help appreciated on what's the best/safest way to rollback to 8.8.5!
  • Sun, Sep 3 2017 1:54 PM In reply to
    • LDV20
    • Posts 169
    • Points 2,025
    wildbeastfilms:
    Pretty easy - just go through the un-install process of 8.9.1.   After completed then go to the download page and download 8.8.5 - then install.  So far for me all is ok - if you want, you may want to contact avid support before you do anything. Up to you.
    Linking bugs were supposed to be addressed in 8.9.1 - but seems you came across one - maybe report it.
  • Sun, Sep 3 2017 2:44 PM In reply to
    Will give it a go....and will report too.
    Thanks for the guidance, much obliged!
  • Thu, Sep 14 2017 7:47 PM In reply to
    • bannerman
    • Canada
    • Posts 63
    • Points 780
    Can anyone confirm if this version works with two monitors with different resolutions. That used to be no problem in Avid. Then they made it a problem. I am still using 8.6.5 and can't update untill the address this.
    Further discussion here:
    http://community.avid.com/forums/t/179732.aspx?PageIndex=2
    Current MC. i7-4930K CPU @ 3.40GHz, 6 Cores/12 Threads. 32GB DDR4. Windows 7 Pro. GeForce GTX 760 4GB GDDR5. [view my complete system specs]
  • Thu, Sep 14 2017 8:31 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 591
    • Points 6,695
    it does NOT work :-(
    symphony 2018.12.1 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Thu, Sep 14 2017 9:32 PM In reply to
    • bannerman
    • Canada
    • Posts 63
    • Points 780
    Wow. That's too bad. Guess I'll keep working with the current version. Thanks for letting me know!
  • Fri, Sep 15 2017 2:04 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 187
    • Points 2,220
    I was really excited about this release now supporting h.264 with the generic plug in.
    I'd had problems in earlier releases with timecode mismatch between what Avid's AMA and transcode created and the source, which was problematic when using AAF's to link to original media for color in Resolve.
    That problem seems to be resolved with the generic plugin support. However, it seems to be having some odd behavior when dealing with audio from MP4 files. Occasionally when playing back files in either the source window or in the timeline, an exception error pops up: "AMA Plugin-In Unable to Provide Sample"
    avid error
    Theses sequences were pretty simple, with just some 20 frame dissolve transitions between video and audio clips. When editing one sequence this error seemed to pop up at a specific spot in the timeline, just prior to an audio dissolve transition. Removing and re-creating the dissolve seemed to fix that particuliar instance.
    This also pops up when trying to transcode the sequence. It will start transcoding the media and then at some point this same error pops up.
    Trying to export the sequence, the export hangs when it gets to the end with the export progress dialog box never closing. Avid is unresponsive.
    Oddly enough I can export just the audio from the sequence as a wav file which works fine, then import the wav and replace the existing audio track with the wav file. I can then export the entire sequence without issue.
    MP4 Files in this case are from a GoPro Hero5 Session. The source media plays back without error in apps like Premiere Pro and Resolve.
    Specs on one file are as follows:
    General
    Complete name                            : F:\GOPR0297.MP4
    Format                                   : MPEG-4
    Format profile                           : Base Media / Version 1
    Codec ID                                 : mp41 (mp41)
    File size                                : 750 MiB
    Duration                                 : 1 min 44 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 60.2 Mb/s
    Encoded date                             : UTC 2017-07-09 11:37:09
    Tagged date                              : UTC 2017-07-09 11:37:09
    AMBA                                     :   x
    Video
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : High@L5
    Format settings, CABAC                   : Yes
    Format settings, RefFrames               : 1 frame
    Format settings, GOP                     : M=1, N=15
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate mode                            : Variable
    Bit rate                                 : 60.0 Mb/s
    Width                                    : 2 704 pixels
    Height                                   : 1 520 pixels
    Display aspect ratio                     : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (30000/1001) FPS
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.487
    Stream size                              : 748 MiB (100%)
    Title                                    : GoPro AVC
    Language                                 : English
    Color range                              : Full
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Bit rate mode                            : Constant
    Bit rate                                 : 128 kb/s
    Channel(s)                               : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Compression mode                         : Lossy
    Stream size                              : 1.60 MiB (0%)
    Title                                    : GoPro AAC
    Language                                 : English
    Other #1
    Type                                     : Time code
    Format                                   : QuickTime TC
    Time code of first frame                 : 12:00:29:01
    Time code, striped                       : Yes
    Title                                    : GoPro TCD
    Language                                 : English
    Bit rate mode                            : CBR
    Other #2
    Type                                     : meta
    Bit rate mode                            : VBR
    Other #3
    Type                                     : meta
    mdhd_Duration                            : 104571
    Bit rate mode                            : VBR
    MC 2018.4 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. MC 2018.5 Asus... [view my complete system specs]
    Filed under: , , ,
  • Fri, Sep 15 2017 2:33 PM In reply to
    • Posts 10,168
    • Points 217,505
    Hi there....
    This error is almost always caused by Perian being installed on the system.
    Uninstall Perian immediately. Also be aware Perian has several additional files that come when installed.
    Make sure you are able to uninstall all of them.
    If you do not have this installed.... ping me back and I will dig into this further.
  • Fri, Sep 15 2017 2:40 PM In reply to
    • Erik
    • Austin, TX
    • Posts 187
    • Points 2,220
    Perian is not installed. I'm not even sure what that is.
  • Sun, Sep 17 2017 2:46 PM In reply to
    • bonang
    • Boston, MA
    • Posts 346
    • Points 4,275
    Erik:
    Probably because Perian is mac-only...
    Avid MC 2012.12 with Symphony option | HP zbook 17" G3 / i7 6820HQ / 32GB RAM / 512GB SSD / WIN 10 PRO 64 / nVidia m3000m / BMD UltraStudio 4K [view my complete system specs]
    Keith
  • Sun, Sep 17 2017 7:55 PM In reply to
    • Erik
    • Austin, TX
    • Posts 187
    • Points 2,220
    Well, that would certainly explain why I don't have it installed on my PC.
  • Mon, Sep 18 2017 11:47 PM In reply to
    • Erik
    • Austin, TX
    • Posts 187
    • Points 2,220
    I just finished editing another sequence with AMA linked h.264 GoPro media and did not see the "unable to provide sample error". However, I took a slightly different workflow this time.
    Before I was doing a prelimary edit using AMA linked media and round-tripping to Resolve 14 with an AAF linking to media and choosing in Resolve to use the camera files to do the color, rendering DNxHR MXF media without rendering the audio as well. Copying over the new media and importing the AAF to then finish the editing and putting in transitions and graphics, etc...  Avid uses the new MXF media but still uses the audio from the AMA linked media. This may have been where the problem lies.
    This time, I did my prelimary edit using AMA linked media and then transcoded the sequence to DNxHR LB to save space. Then round tripped to Resolve 14 as before choosing to link to the camera files when importing the AAF into Resolve. I Rendered out DNxHR MXF media including the video. Copied over the media and imported the AAF into MC. The sequence refers to the video media from Resolve, but the Avid transcoded media for the audio.
    I finished out the sequence adding titles and transitions and exported without error.
    So I'm suspicous that referencing the DNxHR MXF video media and the AMA linked audio may have confused MC causing this error.
