Latest post Mon, Aug 21 2017 11:14 PM by Andrew0726. 0 replies.
Page 1 of 1 (1 items)
  • Mon, Aug 21 2017 11:14 PM
    • Andrew0726
    • Joined on Fri, Aug 18 2017
    • Posts 3
    • Points 35
    Codecs for archival footage
    I'm working on Mac 10.10.5, Avid 8.6 and I'm working on a project that uses 2048 x 1152  footage so the project is set to that.  Our archival footage ranges from 480 - 1080.
    When I transcode the archival footage, the codec options are all DNxHR codecs when keeping source dimensions and source frame rate.
    Is it ok to use a DNxHR codec for low res footage like 480?  The link here says that DNxHR is for resolution above 1080:
    https://en.wikipedia.org/wiki/List_of_Avid_DNxHD_resolutions
    But I'm keeping the source dimension (480).
    What's the disadvantage to using DNxHR for low res footage?  If it is wrong, what should I do instead?  If it's ok, which kind of DNxHR should I use?  LB, SQ, HQ, HQX?
    Thanks for the help.
    Filed under: , , , ,
