Hi!
I work on a project which was started in AMC 8.8, then switched to a different machine (OSX 10.9.5) with 8.6.x. We experienced repeated crushes, so we updated to 8.8.5. Not it's stable but I have an issue with linking footage.
My problem is that I can't get ANY file (dnxhd .mov, h264 .mp4, mp3, wav....) to be accepted through "link". I ALWAYS get the message "...cannot be linked. Do you want to import it?". Since it's a project with archive footage we start with low-res-references which are later to be onlined and for the ammount of footage there's just not enough time available to import everything that I need.
I moved the footage to different places, but whatever the source the location (local, raid, server) the problem stayed the same.
I work on OSX 10.9.5 on a MacPro, 2.7 GHz 12-Core, 64 GB 1866MHz. Updating the OSX is not an option, btw. Really hope that it's not what is at the core of the problem here.
It's also the first time I work with the source browser, and I really hope that it's just some stupid detail that I have overlooked. I'd be thankful for any suggestions.
Does the file path...folder they are in...contain any special characters, like !@#$%^&*() or the like? Avid hates that. Also, are you manually choosing the AMA plugin...not AUTOSELECT?
This may be relevant:
http://community.avid.com/forums/t/181028.aspx
This may be 10.9.5 related...?
Just tested on a MacBook Pro. Linking didn't work on OS 10.9.5 and MC 8.8.4. Linking works fine after updating the system to OS 10.10.5 and MC 8.8.5.
So, this unfortunately looks to be OS-related, which is too bad because I'm not in a position to upgrade all Mavericks systems just yet because of dependencies on other software/hardware.
Thank you. So my guess was right. Still sucks. There should be a warning when updating to newer AMC versions, though.
You can try typing "ToggleHideLinkMenus" into the avid console and restarting MC. That will bring back the old link method under File - Input... it might work that way.
Thanks for trying to help, but unfortunately it doesn't work: "There wer errors lining files".
Maybe this machine talk is decipherable by anyone?
p, li { white-space: pre-wrap; }
Open I/O did not discover any plug-ins.
Memory stats: physical = 65536 MB, virtual = 17592186044416 MB, restriction = 0 MB
WARNING: Requested LocateBuffer size 2048MB is the same as current size 2048MB.
Set persistent image cache limit: 200.0 MB in /Users/Shared/AvidMediaComposer/AvidImageCache
Created ADM Device : 1394 Audio
Setting desktop sample offset to: 3072
MCBootstrap::gwhoami = 30
AVX Library V1.5
OpenGL implementation found:
vendor = Brian Paul
renderer = Mesa OffScreen16
version = 1.5 Mesa 6.4
This OpenGL implementation does not support hardware texture render
maximum render dimensions: = 1920 x 1080 at 8 bits per pixel channel
vendor = ATI Technologies Inc.
renderer = AMD Radeon HD - FirePro D700 OpenGL Engine
version = 2.1 ATI-1.24.39
AME CPU Buffer Deallocator Registered Successfully
MonCon Painters: CPU
ACPL transfer type: ???
ACPL transfer mode: Overlapped
ACPL GPU VRAM Capacity: 6144MB
AAF DLL loaded from : libcom-api.so
AAF DLL version : 1.1.0 (0) [0]
Avid Media Access: Device monitor successfully initialized
DFM loaded. 98 entries initialized. Scripts directory '/Applications/Avid Media Composer/SupportingFiles/CodecToolkit_Config/'
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_H264 to /Q7Container/EnableInternalProcessing_H264. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_AAC to /Q7Container/EnableInternalProcessing_AAC. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_MJPEG to /Q7Container/EnableInternalProcessing_MJPEG. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_TIFF to /Q7Container/EnableInternalProcessing_TIFF. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_JPEG to /Q7Container/EnableInternalProcessing_JPEG. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_PCM to /Q7Container/EnableInternalProcessing_PCM. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/EnableInternalProcessing_Alpha to /Q7Container/EnableInternalProcessing_Alpha. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/GenericMXFContainer/MXFSuppressMCAMetadata to /GenericMXFContainer/MXFSuppressMCAMetadata. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/TruncateMasterMobEssenceSlotsToMinumumCommonDuration to /Q7Container/TruncateMasterMobEssenceSlotsToMinumumCommonDuration. Second toggle is not registered.
Failed to setup chained feature toggle from /AvidMediaEngine/Q7Container/TreatVariableFrameRateAsConstantAverage to /Q7Container/TreatVariableFrameRateAsConstantAverage. Second toggle is not registered.MSM directories:1
LocalMDB::LoadMobsFromMDB() inCallback=0x0 sourceOnle=FALSE
mediaDirPath phyMobs logMobs
"/Applications/Avid Media Composer/SupportingFiles/Avid_MediaFiles/" 0.01 sec
total time=0.01 mobs=0
Media Drives:
MPEG Streamclip 1.9.2, OSVolID = -160, 13644 totalKB, 1800 freeKB, 1800 realFreeKB
Promise Pegasus, OSVolID = -147, 5859031000 totalKB, 528406728 freeKB, 528406728 realFreeKB
san200, OSVolID = -109, 117123674112 totalKB, 12841246912 freeKB, 12841246912 realFreeKB
av-blur, OSVolID = -100, 976134380 totalKB, 447996164 freeKB, 447996164 realFreeKB
MAX_INDEXES_TO_READ set to 10240
MXF Indexes in Memory changed to 524288000: Old Size 524288000
In Init ARO Cmds
MTSC state = 0The single frame player will be built for a length of 3600 frames
MSMRescan() took: 0.031843s
------ The AMA MSP cannot be located for clip celebrity-center-gala-2014-1_1MW417
The default render wait time is 50
EWC Play is supported...
PreReads will bias DueTime by 0.000000 seconds.
------ AMA Link To File(s) ------
