Latest post Thu, Aug 3 2017 4:44 PM by pjo. 53 replies.
Page 2 of 4 (54 items) < Previous 1 2 3 4 Next >
  • Fri, Jul 7 2017 7:45 AM In reply to
    Re: Application Manager doesn't show MC 8.8.5 download
    Thank you very much! Best!
    • iMac 27", late 2013: 3,5 GHz Quad-Core Intel Core i7 Prozessor (Turbo Boost 3,9 GHz), 32 GB (1600 MHZ DDR3 SDRAM - 4x8 GB), 1 TB Drive, NVIDIA GeForce... [view my complete system specs]
  • Wed, Jul 12 2017 3:18 PM In reply to
    • pjo
    • Joined on Mon, Jun 24 2013
    • Posts 17
    • Points 175
    I have the same problem...
  • Wed, Jul 12 2017 3:38 PM In reply to
    • Posts 10,360
    • Points 220,105
    pjo
    Can you tell me what version of appman you are using?  Did you try and resync it?
  • Wed, Jul 12 2017 3:55 PM In reply to
    • pjo
    • Posts 17
    • Points 175
    I'm using 17.5.0
    I have resynced it and I hit the clear cache files button.. no change..
    The other odd thing is that on the apps page, to the right of Media Composer, it says "Open" in blue rather than "Current" or "Download"
  • Wed, Jul 12 2017 4:36 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,851
    • Points 20,445
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    pjo:
    Weird the "Open" is for MC|First version. Are you on Mac or Windows OS
    RalphC
  • Wed, Jul 12 2017 7:48 PM In reply to
    • pjo
    • Posts 17
    • Points 175
  • Wed, Jul 12 2017 7:58 PM In reply to
    • RalphC
    • Posts 1,851
    • Points 20,445
      Avid Employee
    Please clear AppMan cache files.
    1. Quit Application Manager from its menu-bar icon at the top of the screen.
              a. Go to MacHD > Applications >Utilites > and open 'Activity Monitor'.
              b. In the activity monitor interface, select the Process Name ‘AvidAppManHelper’ from the column on the left-hand side, Then click the ‘X’ button at the top left to quit the process.
    You should no longer have any ‘Avid Application Manager’ related processes in the ‘Process Name’ column of Activity Monitor.
    2. Delete the following folders:
               HD/Library/Caches/Avid/AppManager/Cache
               HD/Library/Caches/Avid/AppManager/Db
               HD/Library/Application Support/Avid/Licenses
    3. Now once again go to Go to MacHD > Applications > Avid > Application Manager, but this time, double-click on the ‘AvidAppManHelper.app’ file and wait for it to appear in Activity Monitor’s Process list to ensure it’s started.
  • Wed, Jul 12 2017 8:18 PM In reply to
    • pjo
    • Posts 17
    • Points 175
    i did all of that and there is no change..
    I believe I'm the second person in this forum to be told to try this and we both got no change
  • Wed, Jul 12 2017 8:56 PM In reply to
    • Posts 10,360
    • Points 220,105
    Peter
    Let me get a case created for you and someone on it.
  • Wed, Jul 12 2017 9:03 PM In reply to
    Hello,
    I have the same problem and tried the same things as Peter ... so I am also curious to know, thanks!
  • Wed, Jul 12 2017 9:22 PM In reply to
    • pjo
    • Posts 17
    • Points 175
  • Wed, Jul 12 2017 9:29 PM In reply to
    • Posts 10,360
    • Points 220,105
    Jerry - I will add you to the case notes.
    marianna
  • Wed, Jul 12 2017 9:31 PM In reply to
    • Posts 10,360
    • Points 220,105
    Peter and Jerry....
    Case # 03245265 and I also added myself so I can assist support.
  • Thu, Jul 13 2017 6:03 AM In reply to
    • queeq
    • Joined on Thu, Oct 23 2008
    • Posts 27
    • Points 335
    Same here! I did what you said, Ralph, but no change. AppMan still on 17.5.0 with no updates available. And MC still on 8.8.4, no updates avaiiable in AppMan....
  • Thu, Jul 13 2017 2:49 PM In reply to
    • Posts 10,360
    • Points 220,105
    adding you to the case queeq
