Latest post Mon, Sep 11 2017 3:18 PM by BobRusso. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jun 16 2017 8:15 PM
    • NErez
    • Joined on Wed, Sep 12 2012
    • Posts 82
    • Points 1,095
    ISIS Client for newest OSX
    When will this be released? Why do Avid users always have to be two releases behind the rest of the world because Avid's shared storage solution doesn't support the most recent OS?
  • Fri, Jun 16 2017 8:20 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: ISIS Client for newest OSX
    The Avid NEXIS Client is available on the Avid Download Center and works with ISIS 4.7.5 or later. The NEXIS client supports MacOS Sierra.
    There will be no OS compatibility updates to the ISIS Client.
  • Fri, Jun 16 2017 9:05 PM In reply to
    • NErez
    • Posts 82
    • Points 1,095
    Thanks for the info. Much appreciated.
  • Mon, Sep 11 2017 11:47 AM In reply to
    • nigelad
    • London UK
    • Posts 528
    • Points 6,120
      Avid Certified User
    Thanks for the info. Does this apply to the latest Nexus release - 7.7?
    I'm bulding a new ISIS client with Mac OS 10.12.5, MC 8.9.1, PT 12.8.1, and was using ISIS Client 4.7.11.
    Can log into ISIS but can't mount any volumes.
    I'll give this a go.
    Nigel
    ISIS 5500, MC 18.4 & PT 18.4 on Mac OS with BMD Mini-Monitors, an UltraStudio 4K and AJA T-taps. [view my complete system specs]
  • Mon, Sep 11 2017 2:13 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
    The ISIS 4.7.11 client will not work and is not supported with 10.12.x. You must use the NEXIS client. Uninstall the ISIS client and install the NEXIS 7.7 client.
  • Mon, Sep 11 2017 3:09 PM In reply to
    • nigelad
    • London UK
    • Posts 528
    • Points 6,120
      Avid Certified User
    Thanks again Bob - that worked.
    I'm still having issue with Flash meaning I can't access the administration tools. The old [v15] Flash installer on the ISIS fails on Sierra, and the latest version downloaded from Adobe doesn't fix the issue. Is there a workaround? Otherwise I'll try installing Chrome.
    regards
    Nigel
  • Mon, Sep 11 2017 3:18 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
    You can and should use the latest version of Flash. If you're referring to Safari, please see page 20 of the v7.7 readme; plug-ins need to be enabled.
    Flash will need to be enabled with Chrome also.
