Latest post Thu, Nov 2 2017 1:28 PM by Marianna. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Jun 12 2017 3:28 PM
    • Blackburst1
    • Orlando, Florida
    • Posts 42
    • Points 520
    Crashing on Exit and when using effects and AMA
    I've had a solid system for years now. After upgrading to 8.8, I'm experiencing a lot of issues. I've been in touch with support and I've been installing all the latest updates up to 8.8.4 now...
    The issue is primarity crashing when using basic effects (CC, resize, keys & mattes) and when working with AMA files. Also it crashes when closing the app almost every time. Strait cuts on DNxHD media, very stable.
    Support has had me clean reinstall Media Composer and wipe user profiles & preferences... hasn't helped. Can anyone lend some advice?
    System Specs:
    - Avid Media Composer 8.8.4
    - Dell 7910 Workstation
     - Dual Xeon E5-2630 v3 8-core 2.4Ghz
     - 32GB ram
     - AMD FirePro W7100
     - Blackmagic Design DeckLink Mini Monitor
    - Windows 10 64 bit
    - Avid Media Composer - Dell 7910 Workstation - Dual Xeon E5-2630 v3 8-core 2.4Ghz - 32GB ram - AMD FirePro W7100 - Blackmagic Design DeckLink... [view my complete system specs]
    Walter Lowe
    Blackburst Entertainment
    wlowe@blackburst.net
    http://blackburstentertainment.com
  • Mon, Jun 12 2017 3:54 PM In reply to
    • Blackburst1
    • Orlando, Florida
    • Posts 42
    • Points 520
    Re: Crashing on Exit and when using effects and AMA
    Follow up questions:
    - On the v8.8 Readme Doc for compatibility:
      - it says Quicktime version 7.7.9 for Windows, and then in the notes it says "Quicktime is not supported for Windows 10". What does that mean? Isn't pretty much everyone running Windows on 10? Does that mean I should un-install Quicktime?
      - Nvidia drivers are specified, but I'm on a qualified AMD video card. Why aren't AMD drivers specified here? What is the recommendation for AMD driver version?
    Walter Lowe
  • Fri, Jun 16 2017 4:55 PM In reply to
    • Blackburst1
    • Orlando, Florida
    • Posts 42
    • Points 520
    Thanks for all the replys! [sarcasm] In case anyone else is having the same issues, it turned out to be the AMD FirePro video driver version. The document specifing the driver version is vague and not clear. I tried an alternative and it's back to being rock solid. Really alarming that after numerous contacts with Avid support, they didn't catch the driver version, even with me including it in my initial complaint details.
    Walter Lowe
  • Fri, Jun 16 2017 5:18 PM In reply to
    • Posts 10,079
    • Points 216,495
    Balckburst
    Apologies for not catching this one..... Raff is out so it is me against the world - here, Facebook, twitter etc....
    Where you using the 16.50.2701 driver or did you install that and it worked?  Which one solved it so I can educate support.
  • Mon, Jun 19 2017 4:25 PM In reply to
    • Blackburst1
    • Orlando, Florida
    • Posts 42
    • Points 520
    Thanks Marianna,
    I was using 15.20.1045, because in the doc in specifically listed my display adapter model (W7100) in a list for that driver.
    In the paragraph above for 16.50.2701 is says 'one driver for all' but listed specifially HP workstations (I'm on a Dell) and didn't list my model # by name, so I thought this driver wasn't for me.... Turns out I DID need to be on 16.50.2701. And that made all the difference, from crashing multiple times a day to being rock-solid.
    Walter Lowe
  • Mon, Jun 19 2017 5:16 PM In reply to
    • Posts 10,079
    • Points 216,495
    Blackburst....
    Good to hear - now to have the doc be a little more specific.  :)  off to bug people.
    marianna
  • Thu, Nov 2 2017 12:27 AM In reply to
    Mmm this made no sense for me. I'm having the same problem. Was working off an old version for years and now the system crashes a lot on the same project (I'm on the latest Avid version). It crashes for AMA stuff as well and when I want to use the edit effect tool whther it be a shortcut or in the menu.
  • Thu, Nov 2 2017 10:53 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,620
    • Points 60,370
    MargueritedeB:
    Can you put your system specs and GPU driver version in your signature line? It might help others help you. Thx
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Nov 2 2017 1:28 PM In reply to
    • Posts 10,079
    • Points 216,495
    BarkinMadd:
    MargueritedeB:
    Spot on barkin..... we need to know what you have in order to help.
