Latest post Tue, May 30 2017 1:24 PM by Bruno M. 6 replies.
Page 1 of 1 (7 items)
  • Fri, May 26 2017 8:41 PM
    Problems importing MXF files
    Hello,
    I am currently using AVID Media composer 8.4 on one of our computers and am having many issues importing MXF footage shot on my C500. I have downloaded the MXF plugins but my computer is having a hard time finding a route for the footage.
    If i select an MXF clip individualy I can link it, but as soon as I'm one folder up stream it cant recognize it and tells me "unable to link clips at..." This is very frustrating and time consuming as I have had to import clips one at a time, or moved all the mxf clps into one folder so I could select them all at once. Either way it is not an efficient way of getting the footage into my project.
    I have attached photos to show my plugins. All the footage is in the MXF folder. If i select the folder it doesnt work. If i go inside the folder and select the clips it works.
    Is there something in my settings preventing my computer being able to search folders? Am I missing a plug in?
    iMac pro 2.5 GHz Intel Xeon W 128 GB 2666 MHz DDR4 radeon Pro Vega 64 [view my complete system specs]
    Filed under: , , ,
  • Sat, May 27 2017 12:09 AM In reply to
    Re: Problems importing MXF files
    Have you tried selecting the first clip then going to the bottom of the list and Shift Click on that to select all the files?
    Then press Link?
  • Mon, May 29 2017 9:26 PM In reply to
    Yes I have tried that, and it actually works. In the pictures I linked it shows I choose a single file from a long list of MXF's. Thats because I had already moved all the clips into a single folder so I could import them all at once. When we import from the C500 each MXF clip is in it's own folder with it's data files and thats when my AVID is running into issues.
    If I directly link the files I can import but as soon as I am 1 folder upstream it cannot seem to find them.
    So I can link MXF files into my AVID projects. I either have to go into each folder and link one at a time or move each MXF file into a communal folder so I can "Shift Click" them all at once and link them. Both ways take very long and are very tedious.
  • Tue, May 30 2017 11:54 AM In reply to
    Are you actually AMA linking to the correct C500 folder? It should be the contents folder with all the sub folders intact as they are from the camera. No collected MXF files.
    It won't work if you step down one folder it only works at the correct folder level.
  • Tue, May 30 2017 1:24 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 560
    • Points 7,130
    Pat Horridge:
    As Pat says, you need to select the correct folder level for Avid to successfully link to the media.
    With Canon cameras, th structure is usually as shown below...
    This is how it comes from the camera card, and you must not change this structure at all, or move any files around. You simply put the whole folder structure within an empty folder (say, called 'Roll 001') and point Avid to this folder.
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Tue, May 30 2017 1:35 PM In reply to
    • Bruno M
    • London, UK
    • Posts 560
    • Points 7,130
    Pat Horridge:
    With Canon cameras, the structure is usually as shown below...
    Contents - Clips001 - CM001
                                     - CM002
                                     - CM003
