Latest post Sat, Apr 15 2017 2:23 AM by TheTrex. 3 replies.
  • Wed, Apr 12 2017 2:38 AM
    • TheTrex
    • Joined on Tue, Apr 11 2017
    • The Jurassic
    • Posts 7
    • Points 85
    Best Settings for Alpha RGB in After Effects to bring into Avid?
    Hello Everyone,
    Hello Everyone,
    I am having some issues with importing Alpha RGB titles in Avid Media Composer. I am importing these Alpha RGB transparent text and lower thirds into Avid than I am cutting them into the timeline and they are glitching the footage when I lay the text over the footage. I must be doing something wrong that is causing this issue. I know it's not a hardware issue. I  am editing in avid 1920X 1080 29.97. When I remove the Alpha text I don't get glitchy jumps in my video. Thanks for your patience and help!
    These are my settings for Alpha RGB from After Effects
    RGB+Alpha Quicktime
    Color: Straight Matted
    Format Options Animation
    Importing into Avid
    Alpha Channel-Invert on import White=Opaque
    Image Size Adjustment-Image Sized for Current Format
    Color levels
    Scale from Full Range to legal range
    Autodetect sequentially numbered files
    I brought these in with an MFX 45 what other numbers do you suggest? Here are my options for MXF 45, 100, 145, 220 MFX?
    Homebuilt Avid Media Composer Workstation: Asus X-99 Pro, 32gb of GSkill DD4 Memory, i75930k 3.5ghz, Nvidia Quadro M4000, Nvidia Geforce GTX 1060 6gb... [view my complete system specs]
  • Sat, Apr 15 2017 12:47 AM In reply to
    • TheTrex
    • The Jurassic
    • Posts 7
    • Points 85
    Re: Best Settings for Alpha RGB in After Effects to bring into Avid?
    When I render I get the glitchy jumps in video.
  • Sat, Apr 15 2017 2:15 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    This is most likely the GPU render bug. See this thread for more information:
    http://community.avid.com/forums/t/179757.aspx
    Dave S.
  • Sat, Apr 15 2017 2:23 AM In reply to
    • TheTrex
    • The Jurassic
    • Posts 7
    • Points 85
    Thankyou!
