Latest post Tue, Apr 4 2017 8:52 PM by shirip@mfasocdoc.com. 3 replies.
  • Sat, Apr 1 2017 11:44 PM
    Error message in ama link xavc format from the sony fs5 camera
    Hi
    I am currently i  Africa creating a video with Sony Fs5 camera.
    i am trying to ama link the avc footge and avid media composer is showing me  message that there are no clips in the files or that he unable to link to file or foldr,
    i am pretty withut good internet so i cant really look for totorials,
    Hope to get any assitance ,
    Thank you
    Shiri
    Filed under: , , ,
  • Sun, Apr 2 2017 10:46 AM In reply to
    Re: Error message in ama link xavc format from the sony fs5 camera
    Which exact format is it - is it XAVC-L, or is it AVCHD?
    With XAVC, you need to install the Sony plugin (or Nablet - more on that later).  The plugin doesn't support XAVC-S, but I don't think the FS5 uses XAVC-S anyway, so you should be OK.
    For AVCHD, you use the AVCHD plugin, which is part of MC and doesn't require an additional install.  However, I think I've had difficulty with Sony AVCHD media before, so I don't know how well it'll work.
    If it's XAVC - which version of MC is it?  If it's v8.3 or newer, you'll need the newer Sony plugin from Nablet.  If it's older than v8.3, you need the older plugin from Sony.  All the info is HERE.
  • Mon, Apr 3 2017 9:37 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    The FS5 is XAVC-L. When linking, you must point to the root (XDROOT) folder, NOT the folder containing the media.
    Dave S.
  • Tue, Apr 4 2017 8:52 PM In reply to
    Thank you!!
    For some reason I transcoded most of the materials and now it doesn't ama link again without any error message, just leave the bin empty. what can it be? Shiri
