Latest post Fri, Mar 31 2017 9:53 PM by ryguy. 2 replies.
  • Thu, Mar 23 2017 6:18 PM
    • ryguy
    • Joined on Thu, Apr 30 2009
    • Posts 141
    • Points 1,995
    Render Glitches
    Hi All, I am doing a project where in some parts of the timeline I have some effects and video stacked four levels deep. On some of these sections I am getting a red line on the TC1 layer and it isn't playing back in real time. So I have been rendering that section and the second problem happens. The rendered part has a flash frame or even a partial image from a completely different piece of video. These flash frames need to be rerendered in order to fix the problem. they are hard to notice at first and so the video is going out with these flash frames that are getting flagged by other people.
    What is going on here!
    Main Workstation: Dell Precision T7600, Windows 10 Pro, Intel Xeon E5-2687W @ 3.10GHz 2x, 64GB RAM, Nvidia Quadro 4000, Running Avid Media Composer... [view my complete system specs]
  • Thu, Mar 23 2017 7:05 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    Re: Render Glitches
    There is a render bug. To fix, disable GPU rendering (settings->render settings->disable GPU effects. See this thread for more info: http://community.avid.com/forums/t/179757.aspx.
    Dave S.
  • Fri, Mar 31 2017 9:53 PM In reply to
    • ryguy
    • Posts 141
    • Points 1,995
    Re: Render Glitches
    Thank you! I have now read the whole thread and am up to speed. I took a lot of heat at work like it was my fault, so I am glad its a known issue.
