Latest post Tue, Nov 1 2016 3:14 AM by Mondo. 3 replies.
  • Mon, Oct 24 2016 11:22 AM
    • alexdetig
    • Joined on Wed, Jan 15 2014
    • Posts 32
    • Points 405
    Hi.
    Am I wrong or does FrameFelx still has the same issues than in the past?
    Tried to make an animation to some sourcs (AMA) clip. In Preview it works fine. But no chance to get the animation to the timeline. See attached pic.
    Any ideas?
    Thank in advance
    Alex
  • Mon, Oct 24 2016 3:58 PM In reply to
    Re: FrameFlex still with issues?
    Did you render the timeline clip? That sometimes helps FF to stick.
  • Mon, Oct 31 2016 2:16 PM In reply to
    You still have the Effect Editor active. Click the TC track to kill it and you should find that your adjustment can be seen and played.
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Tue, Nov 1 2016 3:14 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    Also sometimes you have to select refresh sequence if you've applied changes directly to a source in a bin...
    John
