Latest post Wed, Oct 26 2016 10:46 AM by Az Kola. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Oct 13 2016 8:27 AM
    • Az Kola
    • Joined on Wed, Nov 16 2011
    • London, UK
    • Posts 275
    • Points 3,260
    Symphony 6.5.5 Runtime Error
    HI All
    Have just installed Symphony and trying to test the colour correction tools. However I am getting an error when I try to launch the application. Error attached below. Any help very much appreciate .... Thanks in advance
    http://www.flickr.com/photos/azemkola [view my complete system specs]
  • Thu, Oct 13 2016 7:11 PM In reply to
    • Posts 10,204
    • Points 218,090
    Re: Symphony 6.5.5 Runtime Error
    Did you recently do any kind of a Windows update?
    Spec's on the system would help and MC version? or is this an older sysmphony?
  • Fri, Oct 14 2016 8:20 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Thanks for getting back.
    No windos updates. This is a Z800 Workstation,Win7 64Bit. MC 8.3.1
    I am currently running DS on this workstation too.
  • Fri, Oct 14 2016 6:01 PM In reply to
    • Posts 10,204
    • Points 218,090
    AZ
    There’s not a whole lot to go on, but here are some thoughts (some concrete and others are speculative).
    The dialog error box refers to AvidSymphony.exe.  The AvidSymphony.exe went away long ago.  All M/C installs after the 6.5 release use AvidMediaComposer.exe.  Symphony functionality is available via AvidMediaComposer.exe if the symphony option is enabled.
    I think your system drive may be corrupted with remnants from old or too many installs. It is possible there might be some corruption in the system registry.
    I’m sure you have tried un-installing and re-installing the Avid applications.  Or going back to an earlier restore point
    You may benefit from running windows updates.  You will probably receive an update for the Microsoft Visual C++ Runtime Libraries.  That may help.
    Otherwise the best option would be a clean rebuild of the system drive OS and installation of Avid applications. Note that you should always have a back-up or clone of their clean system drive so you can get back to a recovery point easily.
  • Mon, Oct 17 2016 3:09 PM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    Thnk you Marianna, I shall keep trying till Autumn leaves have fallen off the trees.
    Thanks for you help very much appreciated Smile
  • Mon, Oct 17 2016 7:41 PM In reply to
    • Posts 10,204
    • Points 218,090
    anything comes up based on what I posted, please ping me right away.  those suggestions might give us a clue as to what is happening.
  • Wed, Oct 26 2016 10:46 AM In reply to
    • Az Kola
    • London, UK
    • Posts 275
    • Points 3,260
    So solution, which I should have known, is that I didn't have to run Symphony, so if I run Media Composer instead the Colour Correction tool will be available inside Media Composer Geeked
