Latest post Thu, Oct 20 2016 6:33 PM by Dale Gagne. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Oct 12 2016 4:11 PM
    • farhadd
    • Joined on Tue, Apr 27 2010
    • Posts 43
    • Points 570
    UI bug discovered with Image effects in MC 8.5 and 8.6
    There is a UI bug in Media Composer 8.5 and 8.6. It was reported to me by my users and I've done extensive testing to confirm the details with a clean build and new user and project settings.
    If you apply an image effect to a sequence (e.g. Mosaic or Paint effect) and have the shape highlighted, clicking the 1 frame step button forward or backward (or using the keyboard shortcut) actually causes the shape itself to move around the screen instead of stepping the video forward or backward. The odd thing is it does not happen with the 10 frame skip button, which behaves properly. If you deselect the shape, the 1 frame step buttons work as expected.
    This bug did not happen in MC 8.4.
    Mac Pro Late 2013, Mac OS 10.12.6, MC 2018.12, 6 core 3.5GHz, dual D500 3GB VRAM, 256GB SSD, NEXIS 5500 over 1GbE [view my complete system specs]
  • Wed, Oct 12 2016 7:32 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,814
    • Points 20,015
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: UI bug discovered with Image effects in MC 8.5 and 8.6
    farhadd:
    Can any Moderator repro this and report back, if found bug, I'll have this investigated by support team.
    Regards,
    Ralph
  • Mon, Oct 17 2016 11:50 AM In reply to
    I see it here but I think it is a feature, as the up and down cursor keys nudge the shape up and down. Designed behaviour? Deselct the shape and yes, you move along the clip.
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Mon, Oct 17 2016 1:33 PM In reply to
    • farhadd
    • Posts 43
    • Points 570
    This was not the behavior in 8.4. If the change is documented somewhere in 8.5+ I cannot find it. Furthermore, the 10 frame skip button does not exhibit similar behavior. Shouldn't that move the shape 10 times as much as the 1 frame button?
    Intuitive design would utilize the arrow keys on the keyboard for moving the shape instead of the frame step / skip buttons. If this is an intentional design, it's a poor choice at the very least and something multiple users have complained about to me. I would request that it be changed back to the 8.4 behavior even if it's not a bug.
  • Mon, Oct 17 2016 6:25 PM In reply to
    OK - I agree. I couldn't find an 8.4 but in 8.3, the L-R keyboard keys step through the clip, as you say, but the Up-Down keys do move the wireframe in the monitor, so a kind of halfway house.
  • Mon, Oct 17 2016 7:19 PM In reply to
    • Posts 10,157
    • Points 217,360
    Farhad,
    I created a case and will have the escalation team look at it.  Case # 03062071
    Roger - I added you to the case so you will know what they find as well.
  • Thu, Oct 20 2016 6:33 PM In reply to
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 119
    • Points 1,255
    I have had the same bug with v8.6.1, and v8.6.3
    mac pro 12 core mid 2012, avid v8.6.1 currently, os x 10.11.6, 64 g ram
    Avid MC 2018.10, Avid Mojo DX, Mac Pro, Mid 2012, 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.12.6, ATI Radeon HD 5770, 9TB Internal Storage... [view my complete system specs]
