Latest post Sat, Oct 8 2016 12:31 PM by Dave. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Oct 5 2016 4:22 PM
    • Dave
    • Joined on Mon, Jan 23 2012
    • London, U.K.
    • Posts 43
    • Points 500
    Matrox MX02
    Could anyone suggest why it might be that my Acer K242HL Full HD monitor will not cooperate with the Matrox Mini MX02 - the best that I can achieve is that it will work SOMETIMES after calibration (but most of the time it displays an OUT OF RANGE message) - whilst the LG Flatron D2342P-PN 3D monitor works every time?
    This is true of two separate Windows 10 systems both running MC8.
    System 1: i7 2.67 Ghz; 12Gb RAM; NVidia GTX 960 + Matrox Mini MX02; Windows 10; Avid Symphony version 8. System 2: i5 3.40 Ghz; 8Gb RAM; Nvidia GTX 550... [view my complete system specs]
  • Wed, Oct 5 2016 6:27 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: Matrox MX02
    Be sure to have the screen configured as pixel by pixel or whatever the Acer command is
    Tomas
  • Wed, Oct 5 2016 7:48 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 646
    • Points 7,760
    Re: Matrox MX02
    i'd say refresh rate?
    pretty much all PC displays can only do 60Hz straight.
    mxo will probaly output yuv while screen expects RGB
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Wed, Oct 5 2016 8:03 PM In reply to
    • Dave
    • London, U.K.
    • Posts 43
    • Points 500
    Re: Matrox MX02
    Thanks, Tomas.
  • Wed, Oct 5 2016 8:06 PM In reply to
    • Dave
    • London, U.K.
    • Posts 43
    • Points 500
    Re: Matrox MX02
    Thanks, Lukas, but the MX02 software offers to output both YUV and RGB,- it seems to make no difference..
  • Thu, Oct 6 2016 11:07 AM In reply to
    • David Clarke
    • Joined on Sat, Mar 13 2010
    • Brighton, Sussex, UK
    • Posts 240
    • Points 3,275
    Re: Matrox MX02
    What is the resolution you are trying to output, I.E. what is your project settings?
    Have you tried the Matrox Xtools app and playing through that?  It may help to identify whether it is an Avid problem or just that the MXO2 does not like your screen.
    Laptop - Haswell desktop processor, 16GB RAM, 970m NVidia graphic card. Desktop - 2011 pin Haswell-E processor, 16GB RAM, Thunderbolt, Blackmagic UltraStudio... [view my complete system specs]
  • Thu, Oct 6 2016 11:35 AM In reply to
    • Dave
    • London, U.K.
    • Posts 43
    • Points 500
    Re: Matrox MX02
    Hi David: I'm trying to output 1080P.  I've tried the MX02 with an HP monitor and that too complains about the input.  I get the impression that running the calibration utility begins to make things function but then things fall apart again. I'll look for the XTools app, thanks.
  • Thu, Oct 6 2016 12:46 PM In reply to
    • David Clarke
    • Posts 240
    • Points 3,275
    Re: Matrox MX02
    I have had lots of monitors not like getting a 1080 25P signal.  Many support 30P but not 25 or only support it in PSF mode.  I have an Asus HD computer screen which I am using to type this message which I know will not display a 25P picture from any device I have tried - Blackmagic or Matrox.  I never found a solution and just used a TV instead.   That is not to say that if definately won't work at your end but it possible.
  • Thu, Oct 6 2016 4:07 PM In reply to
    • Dave
    • London, U.K.
    • Posts 43
    • Points 500
    Re: Matrox MX02
    Thanks, David: I think you have nailed it.  I suspect that many editors use a TV as a monitor so I may be being unreasonable in expecting an ordinary screen to work with the MX02.  I'm happy at least that my LG 3D monitor does in fact work,- perhaps the 3D aspect to the device means that it is more tolerant of the input.
  • Thu, Oct 6 2016 9:17 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 646
    • Points 7,760
    Re: Matrox MX02
    manual:
    http://www.manualmonitor.com/manuals/acer/Acer_K242HL.pdf
    60Hz @ 1080p only.
  • Fri, Oct 7 2016 9:08 AM In reply to
    • David Clarke
    • Posts 240
    • Points 3,275
    Re: Matrox MX02
    I have been trying out some 4K computer screens recently and although they work ok at all the 4K resolutions they sometimes don't work too well at HD and Sd resolutions.  I do not have the problem you are having with no output at all - they give you a picture - but, particularly with Interlaced video, sometimes it is not very good.  So even if you find a monitor which says it will work at the resolutions you want it is still no good.  TVs have circuits which are designed to accept video signals and generally work better.
  • Sat, Oct 8 2016 12:31 PM In reply to
    • Dave
    • London, U.K.
    • Posts 43
    • Points 500
    Re: Matrox MX02
    Thanks for that,- I too am looking at the move to 4K so your experience is helpful.
