Latest post Thu, Oct 6 2016 11:17 AM by mjolnarn. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Sep 23 2016 2:01 PM
    DJI PHANTOM OSMO ISSUE AVID MEDIA COMPOSER
    Hello all,
    I have some questions for Avid about this transcode progressive to interlaced.
    All the product DJI are totally trash interprated by avid when you do a transcode progressive -> interlaced.
    I try new project in progressive and after do an open  bin .. same issue.
    I test timewarp interpratation ... same issue.
    The video flick a lot, this is so ugly.
    The only way i found wich is correct is to pass with after effect and do some tricks.
    The problem is every body now buy drone or osmo ..
    If someone have some tricks to do a proper import of DJI in interlaced project....
  • Fri, Sep 23 2016 9:33 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 171
    • Points 1,990
    Re: DJI PHANTOM OSMO ISSUE AVID MEDIA COMPOSER
    I have had to convert quite a bit of DJI 60p footage to 1080i for use in Media Composer and I finally found a workflow that produces excellent results.  Unfortunately, it requires converting the footage with Adobe Premiere Pro.  The trick is to set the PP Field Options to Flicker Removal and add Anti-Flicker amount of .5 and render out at DNxHD 220x 1080i.  I'd love to hear if anyone is having success within Media Composer.
    Primary System: Media Composer Ultimate 2021.12.x | Avid Artist DNxIO | iMac 2020 i9 10-Core 3.6/128GB/2TB-SSD/Radeon Pro 16GB / OS 10.14.6 | Artist Color... [view my complete system specs]
  • Sat, Sep 24 2016 9:33 AM In reply to
    • fsm
    • Joined on Tue, Nov 24 2009
    • Germany
    • Posts 181
    • Points 2,195
    we do the same here, first load your dji footage to premiere timeline, right click  "Field options"(?)"flicker removal" and output the sequence to the file you want.
    we've found no good looking solutions inside media composer or with the bcc effects.
    MC 2021.12 & SYM / BM Monitor4K / Windows 11 (i know ...) 64 bit / i7 12700k / RTX3070 [view my complete system specs]
  • Sat, Sep 24 2016 9:38 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    No problems with converting 50 p to 50i here, and all in Avid, no external filters, just apply the timewarp settings that works best
    Tomas
  • Sat, Sep 24 2016 9:45 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    yderunes@eliote.com:
    And this is the wrong workflow, you want to link the 50 p media inside a 50 i project , then render out timewarp with the correct settings, I suppose it´s the same with 60p to 59.94i but cannot be sure of course
    Tomas
  • Sat, Sep 24 2016 11:18 AM In reply to
    • fsm
    • Germany
    • Posts 181
    • Points 2,195
    Youre right, but its still flickering a lot if you change the 50p to 50i.
  • Sat, Sep 24 2016 1:50 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    fsm:
    Not on my systems and after a render, what settings do you use
    Tomas
  • Thu, Oct 6 2016 8:01 AM In reply to
    Thank you all, effectively i test a lot of solutions but the good one is to use After effect Or premiere pro and apply an anti flicker effect reexport in dnx for fast import after in AVID.
    I hope avid will do something in the next versions ....
  • Thu, Oct 6 2016 9:33 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    I think that I described above how you should handle this in Avid
    Tomas
  • Thu, Oct 6 2016 11:17 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    fsm:
     This is from earlier this year, a teaser for a fight cancer event, I wanted 1080 50i and got 1080 50p .
    Converted in Avid to 1080 50i , exported out a QT ref to Squeeze and used the deinterlacer in Squeeze to make it 25 p.
    It´s also downconverted in Squeeze to 720 with " keep aspects " so 720 25p
    Quite watchable if I might say so
    https://www.youtube.com/watch?v=LHplwzXy6mc
    Tomas
