Latest post Sat, Nov 26 2016 9:51 AM by GhislainT. 7 replies.
  • Mon, Aug 29 2016 4:46 PM
    login to interplay failed: format descriptor
    Upgraded MC from 8.4 to 8.6.1 today.  The version Matrix says its supported interplay 3.3.0
    But I get the error  login to interplay failed: format descriptor
    I tried patching access to 3.3.1 no luck.
    Application works otherwise just cannot connect to Interplay.  It does still connect to Isis so I can see the media drive.
    Any ideas?
  • Mon, Aug 29 2016 5:38 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,400
    Re: login to interplay failed: format descriptor
    Did you also installed the right interplay framwork with the Editor? Might be you are using a newer editor on older (8.4) framwork.
    Best, Menno
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Mon, Aug 29 2016 5:59 PM In reply to
    hmm.
    I will look into that further.
    Would I have to change the framework on the server side as well?
    David
  • Mon, Aug 29 2016 6:03 PM In reply to
    We are on 1.8 on the framework, which seems to be current.  There is a 1.8.1 available.
    I was hopping to not have to do any Interplay upgrading for the MC 8.6 to function.
    David
  • Mon, Aug 29 2016 7:19 PM In reply to
    • Baklap
    • Posts 6,944
    • Points 82,400
    Hi David, no you should not update server side as it is supported (as stated in the version matrix) but on the client side I think the framework sshouldbe compatible with the editor version. This is an assumption though, it might be that the current version does not understand the older framework thus throwing an error on start. It would be my first option.
    Hope it helps.
    Menno
    Twitter Account
    My Keys
  • Tue, Aug 30 2016 3:52 PM In reply to
    Solution was to download the Interplay Production Client software, and install on the client.  Not neccessary to upgrade on server.
    Thanks for all the help.
    David
  • Tue, Aug 30 2016 7:51 PM In reply to
    • Baklap
    • Posts 6,944
    • Points 82,400
    Yeah you did good, awesome it's all up and running again.
    Best, Menno
    Twitter Account
    My Keys
  • Sat, Nov 26 2016 9:51 AM In reply to
    • GhislainT
    • Joined on Fri, May 27 2016
    • Posts 1
    • Points 5
    Hi, i have the same problem with the login Interplay but i dont find the install for framework 1.8.1 in download center.
    Thanks for help
    Ghislain
