Latest post Fri, Sep 16 2016 5:16 PM by Sion Roberts. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Aug 13 2016 8:21 PM
    • Robert B
    • Joined on Sun, Aug 7 2011
    • Los Angeles
    • Posts 83
    • Points 1,005
    Render video clip effects with handles
    Appologizes if this is redundant.
    It would be amazing to have the option to render all clip-based effects with a user definable set of handles. When working with really heavy effects (BCC 10), making a tiny trim or changing from a cut to a dissolve can blow away a 12 minute render.
    I'd rather increase my initial render time by including handles than re-rendering when I'm fine-tuning edits. If further changes to a clip are within the handle threshold the Avid shouldn't "go blue".
    To make this work there may also need to be a "keyframe lock" that prevents the start or end keyframe from changing position during a trim operation as this would require a re-calculation by the effect. Anyhow, I'll leave the mechanics of this to smarter people:)
    This could be implemented as just another type of render: Render, Expert Render, Render with Handles
    -Robert
    OFFICE: 3.5 GHz Core i7 Late 2013 Imac running OSX 10.11 with 32GB RAM. NVIDIA GTX 780M 4096 MB. Avid Media Composer 8.5/ Pro Tools 12.4 MOBILE: 17"... [view my complete system specs]
    Filed under: , ,
  • Fri, Sep 16 2016 5:16 PM In reply to
    • Sion Roberts
    • Joined on Mon, Dec 5 2011
    • Manchester
    • Posts 28
    • Points 370
    Re: Render video clip effects with handles
    This is a great idea.
    Robert, you may find it helpful to switch from 'Elastic' to 'Fixed' in the right-click keyframe menu. This effectively locks your keyframes into position and (I think) if you do a trim on the effect it'll only need to render the new portion of the clip if nothing else has changed.
    The above doesn't apply to the older plugin UIs (e.g, paint/animatte) - only the newer ones with advanced keyframing (which includes pretty much all your BCC/sapphire effects)
    HP Z820 Intel Zeon CPU E5-2640 @ 2.50GHz, 32 GB RAM, Nvidia Quadro M4000. Windows 10 Pro, Avid Media Composer... [view my complete system specs]
