Latest post Tue, Aug 9 2016 2:18 PM by Marianna. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • Wed, Aug 3 2016 8:17 AM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Re: Timeline wavform display shifts when zooming in, showing incorrect selection.
    AndrewAction:
    The editing application saves cached waveforms for projects. You will see a WaveformCache folder in the Avid Projects directory. The WaveformCache folder also appears in the Shared Avid Projects directory.
    I see four WaveformCache....awf files in the regular project folder.  Is it normal to have more than one?  Do I just delete these four files, or do I need to delete files from somewhere else as well?
    L
  • Wed, Aug 3 2016 6:25 PM In reply to
    I had 4 files in each location here. I did not pay any attention to the file extensions at the time. Those 2 cache folders are still empty this morning. Maybe Jef or Luca who are experiencing these issues can shed some light on this.
  • Wed, Aug 3 2016 8:05 PM In reply to
    I've been through all the suggested solutions and tests listed in this thread and a few more before and the conclussion I came to was its a bug in the way MC calculates the waveforms.
    I eventually gave up trying to find a solution or cause and concluded its related to the content (that actual Audio and some random MC internal issue)
    Was then filed away and another useful feature with a flaw that comes to bite just when you don't need it to.
    I have other tools that let me work round the issue and just revert to those.
  • Wed, Aug 3 2016 8:50 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,375
    Thank You for trusting me this much Andrew! I'll try my best: MC should automatically rebuild the waveform cache files when deleted; in order to make sure that MC does its job thoroughly I'd trash the "usual suspects" as well, for a real fresh start of the project. Unfortunately, as of MC 8.6.1, the relevant files have changed, and I did not dig enough to be more precise, but I believe that the usual suspects are still at stake, and hope that they behave the same way as the old ones, and self rebuild after being deleted. Reading the MC's "What's new" and "Readme" files will shed some light on the new naming. I don't know how MC translates old projects to the new standard, and if it manages the project files avoiding conflicts, and my best guess is that the new audio features introduced with MC 8.6.1 may bring variables to the game. Brand new projects created with MC 8.6.1 shouldn't be an issue, but I do not know if trashing the usual suspects in projects created with older releases of the software will trick MC into thinking that it's dealing with a true MC 8.6.1 project. If You want to experiment I suggest to do Your tests on a bogus project, or to make first a backup copy of the project You're fiddling with.
    My thought goes to Larry. Sad
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Wed, Aug 3 2016 9:32 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    AndrewAction:
    Where exactly is the second location (i.e. not the one in the regular project folder)?
    I also think that this issue is somehow related to the actual audio file, but that the bug is defintely in Avid.  I see a definite pattern to certain files having this issue, which implies a connection to the file.  Avid is able to see and build the wavefore display just fine, and it looks correct and consistant, but it "shifts" when zooming in, and no longer lines up with what you hear.  I believe this points to an issue with Avid's "display" function -- specifically the way it zooms.  Avid is showing it correctly but just not anchoring it to a certain spot throughout the zoom range.
    L
  • Thu, Aug 4 2016 6:46 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,375
    lalittle:
    ...I believe this points to an issue with Avid's "display" function...
    I do agree, the problem is not with the cache files, and trashing them resets things for a while, but the shift eventually comes back.
    peace luca
  • Sat, Aug 6 2016 5:57 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,146
    • Points 49,975
    There is an Avid document on how to purge the waveform cache.  One of our engineers found it.  And of course I can NOT find it now.
    Rant alert - Is it just me or is the support site even worse when it comes to searching the Knowledge Base.  Any time I type in a keyword, I get NO result.
    I will try to find the doc and post it if possible.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Sun, Aug 7 2016 8:30 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,950
    • Points 70,375
    Hi Jef, it's not the support site getting worst, it's all of the MS server based sites over the internet that suffer of bad search results... I use to search sites externally, go to google and type "waveform site:http://avid.force.com" in the search box, I've done it already and I couldn't spot the document You refer to though.
    peace luca
  • Sun, Aug 7 2016 5:44 PM In reply to
    • jef
    • Maryland
    • Posts 4,146
    • Points 49,975
    Okay, I found an email from our engineering staff with notes from the doc we can not find:
    Turn off audio waveforms on the tracks
    In the console type in wfalldata
    Turn back on the audio waveforms and it will rewrite the waveform data. It will not be a permanent fix and will need to be repeated when you need to be accurate again.
    Good luck,
    Jef
    Jef Huey
  • Mon, Aug 8 2016 8:45 PM In reply to
    • Posts 11,716
    • Points 257,480
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Folks,
    I created a case ( #03011688 ) and have sent it to support with all the notes on this thread.
    Larry --> you are point on this but I added Jef, Pat and Andrew to the case so they know what gets found."
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Mon, Aug 8 2016 10:03 PM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Marianna:
    Folks,
    Thanks Marianna -- I appreciate you looking into this and getting the information to the right people.
    This issue has the potential to cause some real headaches.  So far I've been be able to go back and re-manipulate my source files in ways that for some reason (luckily) prevent the issue from occuring, but if I hit a situation where this doesn't work, it will cause serious issues in gettting this project done on time.
    Thanks again,
    Larry
  • Mon, Aug 8 2016 10:08 PM In reply to
    • Posts 11,716
    • Points 257,480
    • ! Avid Employee
      ForumsAdministrator
    Happy to help Larry...
    Im following it so I will make sure we get some traction.
  • Tue, Aug 9 2016 12:02 AM In reply to
    • lalittle
    • USA
    • Posts 534
    • Points 7,365
    Marianna:
    Thanks.  I got the support email and sent the two files that were requested.
    L
  • Tue, Aug 9 2016 2:18 PM In reply to
    • Posts 11,716
    • Points 257,480
    • ! Avid Employee
      ForumsAdministrator
    lalittle:
    L
    I will follow the case.... thanks for doing that Larry.....  shoud help
