Latest post Wed, May 4 2016 8:53 AM by Dan_B. 3 replies.
  • Fri, Apr 29 2016 1:21 PM
    • Hugh Moore
    • Joined on Mon, Mar 29 2010
    • South Australia
    • Posts 44
    • Points 570
    NVidia GTX 750 Ti
    I have a GTX card in my system, and this is not working properly. My old card was Quadro Fx580 which works fine, but got carried away and bought a GTX Card to help with my Sony 4K Video.
    Im using 8.3.1 in terms of my licence.
    Ive tried rolling back drivers, and seeking whether I should re-install Windows 8.1 and use older drivers?
    Anyone else using the above GPU and if so, what OS/drivers are you using.
    Appreciate any suggestions.
    I note lots of forum mebers have dual cards Quadro/GTX. Are you running them concurrently?
    Hugh
    MC 8.3.1 MB: Gigabyte EX58-UD5 Video: Nvidia GeForce GTX750 RAM: 12 GB Windows 10 Boot Drive: SSD Monitors: Dual User: Hobbyist [view my complete system specs]
  • Fri, Apr 29 2016 6:52 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 647
    • Points 7,775
    Re: NVidia GTX 750 Ti
    using quadro & gtx concurrently (davinci), works fine.
    if worst comes to worst, win 7 + mc 6.5 or 7 will give you a working setup sans 4k
    i'd widesr range of drivers to choose from.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Sat, Apr 30 2016 3:54 PM In reply to
    • jcfrance
    • Joined on Wed, Apr 21 2010
    • Posts 31
    • Points 300
    Hi Hugh,
    It seems that since version 8.5.2 my GTX 980 TI is recognized and now the launch of AVID at the splash, I get the message that my card is Qualified.
    Avid 8.5.2 has changed. Before there was a QualifiedGpuBoards.txt file that listed only certified cards, now that file is replaced by the DisqualifiedGpuBoards.txt file (empty at present) which disqualifies graphics cards. In other words: all cards are Qualified but there will be only when testting with your card that it will be confirmed.
    (i'm on W10 X64 PRO, latest driver NVIDIA Version: 364.72  WHQL for GTX 980 TI, the same for GTX 750 TI)
  • Wed, May 4 2016 8:53 AM In reply to
    • Dan_B
    • Joined on Tue, Nov 26 2013
    • Posts 156
    • Points 1,695
    Traditionally avid only supports specific Qaudro cards with specific drivers.
    That being said there is a shift with 8.5.2.
    When you say my card isn't working properly what do you mean exactly?
    If you mean that your 8.3.1 MC doesn't recognise it as a certified card then thats correct, it will use it for display etc but won't use it to accelerate some of the fx and a few other things.
    In order to fool MC into using your card like a qualified system you need to alter hidden-ish documents which can make the system unstable/unpredictable when rendering/exporting/making video mixdowns.
    My personal recommendation would be to grab a trial version of 8.5.2 and give that a whirl.
    Although having said all of that i'm sure if Avid uses the GFX card for helping to decompress Sony 4k material anyway it may well all rest on your CPU for that.
    Try the trial and see if things improve at all.
