I am trying to install some of the approved After Effects Plungins in FX.
What folder do I put them in?
I have tried several but no luck with themn showing up.
Help
xw8200
4 g ram
fx3400 driver 77.18
xpressHD v5.2.4 with mojo
AvidFX 5.1.5
tex
There's 2 plugin folders in the Avid FX installation folder. I forget which one they go in, but your best way of finding out is to experiment. Put them in one folder, then launch Avid FX. If they don't show up, put them in the other one.
Keep in mind that not all After Effects plugins are compatible in Avid FX. For clarification on which ones are and aren't, go here: http://www.borisfx.com/products/effects.php
Take care.
When 900 years old YOU reach, look as good, YOU'LL not!! Hmmm?
I am trying to install Digital Film Tools Composite suite an approved filter set.
The readme says to put install into:
c:\Program Files\Avid FX\AvidFXPLugins\
There was no folder with that name so I made one, install into it but no new plugins.
I also tried:
However, no plugins. Can anyone help?
You are the man.
It worked perfectly.
