We are pleased to announce the release of Media Composer v8.5.2. This update is available from My Avid Master Avid Accounts, Application Manager, and the Avid Download Center (login and password required).
Documentation [The ReadMe file is also attached to this post.]
Change in this Release:
AudioSuite Change - The menu options “Mono mode” and “Multi Input mode” have been added to the AudioSuite Effect dialog.
Fixes: Included in this update are a number of fixes including but not limited to:
(Mac OS10.11.3) Exporting a greater than 20 minute sequence as a QuickTime movie caused the system to crash. This is now fixed.
(Mac) In some instances, after about 15 or 20 minutes of editing and playing back, the spinning beachball would appear and you would have to force quit. This has been resolved.
“StreamingPlayConsumer Timeout” error messages occurred when playing back in 12-bit quality mode in full stereoscopic projects when I/O hardware was ON. This has been fixed. NOTE: RGB 12- bit mode is not supported with Nitris DX, Mojo DX or software only systems.
In previous releases, the editing application did not support EDL import of 64 audio tracks. This has been fixed.
In some instances, you could not select master clips and export them to an XDCAM device. This has been fixed.
When you performed an AMA File export, the file might not have been placed in the path location that was selected.This has been resolved.
Some keyboard shortcuts were not working in the Paint Tool. This is now fixed.
(Trim mode) In some instances on Mac, when you slowly dragged out a clip, the clip was incorrectly trimmed in the other direction. This is fixed.
In some instances, changing the Capture tool audio channel from Stereo to Mono caused the editing application to crash. This is resolved.
If the Font size was set to 16 or higher, the last clip at the bottom of the bin could not be renamed. This is fixed.
In some instances, a title would be cropped after you saved it in the Title tool. This is now fixed.
And many more…..
How to obtain the Media Composer v8.5.2: (The latest update to Media Composer is available worldwide.)
- Already have v8.5.x? - Customers who have already installed the latest version of Media Composer v8.5 will be notified of the availability of the v8.5.2 upgrade when launched via the Application Manager. The Apps tab will also provide a link to download and install the update when desired.
- New Media Composer Customers - who purchase Media Composer after launch will receive this v8.5.2 update in their My Avid Master Avid Account.
- Customers on current Upgrade & Support plans - can download the Media Composer v8.5.2 update either from their My Avid Master Avid Account or the Avid Download Center (login and password required) when launched.
- Customer not on a current Upgrade & Support plan - must purchase either a new Media Composer Subscription or Perpetual license to receive this v8.5.2 update.
IMPORTANT - This release of Media Composer requires an active Upgrade & Support plan as of launch (Thursday April 7, 2016).
Robert Davis CEO/Creative Director
Davis Advertising, Inc.
Visit my latest blog, "Concept to Creation" on the Avid Community site
[/url] Visit my Behance portfolio site
Any word if the missing Audio Track Effects Tool will be found in the next update?it is not showing up from the Tools dropdown menu (or from the Timeline's Audio track), and the AudioSuite Plugin Editor/Controls Window is not popping up for a smaller percentage of us users.
http://community.avid.com/forums/p/138252/785380.aspx#785380
Hello,anyone can confirm: there is no longer the QualifiedGpuBoards.txt file. I tested my GTX980 TI and qualified directly. We are no longer obliged to have a quatro?
jcfrance: Hello,anyone can confirm: there is no longer the QualifiedGpuBoards.txt file. I tested my GTX980 TI and qualified directly. We are no longer obliged to have a quatro?
Correct
Daniel Frome: jcfrance: Hello,anyone can confirm: there is no longer the QualifiedGpuBoards.txt file. I tested my GTX980 TI and qualified directly. We are no longer obliged to have a quatro? Correct
Tomas
It was about time! Is this official word from Avid? What is the source?
peace luca
yes, that list has been replaced by what will be the disqualified gpu boards listing...
So one way or the other it's still Quadro only?
Can anybody else confirm the following:
1) AMC 8.5.2when I select a muted clip and delete it with "backspace", avid crashes instantly.but if I un-mute the clip first and then select and delet it it works.
did not happen before.
2) this already happend with the last AMC 8.5.1 versionWhen i close a bin, the saving dialogue does not disappear.Only when i hit "Save all", it disappears.
Sorry, wrong forum.
but maybe this also happens on win machines?
Anybody else seeing this I loaded the new update and as I was poking around in it I went to the audio suite and applied an sans amp fx and all I got was the spinning beach ball then pgm crashed so I tried it again same thing 3 times after reboots >>>
Tom Pearson
Dear all,
I have just upgraded MediaComposer 8.5.2 from 6.5, got issue:
MediaComposer > Export Quicktime file (Quicktime version v7.7.9) > Carbon Coder(v3.2) transcoding back to ISIS 5K(v4.7.8) in MXF XDCAM 50 > Can not play media (Quicktime player don't understand file).
Did test:
- Transcoding quicktime file to local drive > Quicktime player can not play MXF.
- Transcoding quicktime file that exported from MC 6.5 to the ISIS > can play MXF.
Any idea to solve it?
Best regards,
Giap
Glap
How big is the file?
Dear Marianna,
~1GB (duration of media is ~ 3mins).
Regards,
Have anybody try and update on this?
